Thanks for leading this
@rockyboy. Had a great time as a beta builder with you previously and may throw in for this with an x-wing Star Wars fighter. Found a bunch who started, one profile build that flew but nothing with a full fuse.
Time to get going with a chuck glider!
Just a heads up on the X-wing, that thing has very little yaw stability and a tendancy for interesting CG due to wing placement and a long fuselage.
watch the takeoff here. They've added rudders to this one, but because they are close to the CG, the aircraft still yaws heavily on takeoff. This is Ramy Rc's model, he wound up modifying it quite a bit after this and a second crash flight
If you're planning on doing an x-wing with a full 3d fuselage and components, don't be afraid to add stuff, like a canard or rudders made from clear plastic to keep looks. If you're doing a profile build, it may be much easier, since the fuselage sheet will push the CL forward without adding a bunch of weight, and the fuselage/engine pods will add more rudder area.
