b-29er
I was thinking a 30inches span would be good. However I was thinking if I could use full size power pods then I would save some money on electronics.
Thanks
If you want to do a 30 inch'ish wingspan I'd suggest going with a twin power pack A, but if you wanted to do it with full size power pods you'd probably be approaching a 40 maybe even 50 inch wing span.
Griff's got it on the nose. Nice thing about Power Pack A is there is a lot of versatility coming off multirotor hardware, so if you feel power is anemic you can go to a 4s, less pitchy props or a larger motor with the same mountings, or if you think its too much of a rocket, drop to a 2s and larger props to keep pitch speed down. I would probably stick to 2-blade props if you like having your plane belly land without chewing through props, but you could go to 3-blade if you want to be that much truer to design. You may need to change up the cowl a bit though to accommodate that engine, but its the right choice. I'd also plan on using some CF or something on the wings just to make sure high-G maneuvers don't cause a wing failure with that much weight so far out (leverage and what not).
Also if you havent designed a plane before, you might take a moment and do something a little more predictable to start off with, like a piper cub or something with simple construction techniques where you can experiment, figure things out, watch videos, etc. Because looking at the fuselage on your guy
