Test Builders welcome
Folks,
I gave this plane a shot at foam conversion. I am overseas and away from all of my hobby stuff. I have not had a chance to construct this to proof the plans. If someone wanted to try cutting this out and assembling the parts, then give some feedback, I would appreciate it. Flying it would be a whole nother issue.
Here is a set of plans. This is just the foam portion. You will need to figure out the hardware mounting. These are arranged to fit on three sheets of DTFB. Black = cut through, Red = score cut. The very nose is rounded top, bottom, and both sides, I would remove the inside paper from those areas.
When you open the plans in Adobe reader, use the snapshot tool to frame in as close as you can around the parts. Print as poster at 100%. If you have any issues or questions, feel free to ask.
Respectfully,
Tommy
P.S. The plans show one spar. Two are needed as the spar is doubled.
