Hey guys if you remember last month I modded my Turnigy 9x to have both the external stock module and an internal OrangeRX DIY module. This issue now is that I am getting very poor range on both modules. With the stock I get around 80m through trees and with the OrangeRX I get around 60m through trees and max 300m in an empty field.
After research I think I can conclude that it is not the TX itself that is the problem, it is the modules because all the TX does is provide power and signal to the modules which is obviously happening. If I'm correct it is the modules job to provide the range. So what I'm thinking is that I may have messed up the antenna on my stock module by trimming the coax a little where it connects to the board. For the OrangeRX I'm not sure if the antenna I got is bad, or if the module itself is bad. No way to tell except to buy a new antenna.
I'm thinking of getting this one from Amazon along with this pigtail. Can someone confirm that will work, it looks the same as what comes with the DIY module. If you guys have any other ideas of what could be wrong please let me know. I can still fly proximity FPV, but I'm dying to get out and explore the area around me without worry of loosing signal. Thanks!
