She looks great!
Flight report sounds like my Mountain Models C-180. Nice and relaxed. Maybe I'll drag my Dumas L-19 kit out next for build. I've got more than enough fast planes. These little floaters just seem to be so much more fun in a different sort of way. When I fly my old C-180 slooowly past at eye level I always have a ridiculous grin on my face. I'm sure this little L-19 will produce the same effect.
Awesome job on yours Rover....
Joe
Yes, The MM C180 and Dumas L-19 fly very similar. I like Dave Blum's designs a bit more than Pat Tritle's, this has more to do with the airfoil.
On the subject of covering no Parklite and So-lite are not the same (very close but not the same). Parklight is a german product from the firm that makes Oracover. So-lite is from an english firm that makes Solarfilm.
The product I now use for these "Stick & Tissue" type builds is called R. A. microlite. Its virtue is that it is much more thermally stable than So-lite. That is it doesn't sag near as much in the sun or summer heat. As a bonus it is also lighter. The only draw back is that it is a higher heat type covering, so may not be suitable for covering over foam.
https://www.homefly.com/products.asp?id=31 (Now called Microlite)
When shrinking these films on ultra light RC models. Use an iron at the lowest setting that will shrink the film. Think of the film as a metal. If you over heat it the "temper" will come out. For films this means they sag real easily for the rest of the model's life. Stay away from the parameter of the part with the iron. You don't want to reactivate the film's adhesive and debond it from the perimeter of the part.
As to basswood the design is large enough to use 1/8 just fine. Not sure why you would want to unless the balsa is so light as to be unsuitable for longerons. A structural note that for the same amount of wood you can use four 1/16 stringers for every 1/8 stringer. This helps make smoother better looking model parts (smaller facets).
Don't know if Dumas has corrected the wing spar but take a look at this thread if you actually plane to fly the model. Cuban Eights and ground loops (dragging the wing tip on the ground) have been know to over stress the Dumas spar!
https://www.rcgroups.com/forums/showthread.php?879893-Dumas-spar-in-their-Electric-R-C-kits
(Pat actually joined the conversation around page 10)
All the best,
Konrad
P.S.
With real light structures, like on 18" RC models, I'll use two irons one on each side of the surface to control warping.
