hotbrass2005
Just before Christmas I got all the thing I needed to put together an electrohub quad with a pixhawk on board. I have everything flying beautifully and am really enjoying it, but the flight times aren't great.
I purchased 4 multistar multirotor batteries hoping to get something in 20 minute flight range with everything on board: 2x4000mah 3S batteries, and 2x5200 mah 3S batteries. They are all 10C rated batteries. My voltage alarm is set to 10.6V and goes off after about 6-7 minutes of flight with the 4000mah batteries and about the same with the 5200 mah batteries. When I charge the batteries, the 5200mah batteries are taking about 1900 mah. The 4000mah batteries take about the same - far below what I expected.
I'm think what is happening is that the quad needs more current than what the low C rated batteries can provide, so it's causing the voltage to sag. I should mention that at rest, the batteries still show about 11.8V. If so, what are my options? New batteries with a higher C rating? New motors that pull less current? Maybe switch out the 1045 for 9 inch props?
