Ok, hard part is done...but still need a way to control this thing! I already decided to give the openLRS a go on this build so I looked for where I'd like to make it fit. I decided on the back "patio" made the most sense but experience has taught me it needs some protection. So I cut a pad of 1/4" black craft foam just slightly larger than the unit, then pressed it into the foam to show where I would have to carve out clearance for the crystal on the RF Module. I had to expand it a bit more than I expected but eventually got a shape that fit well:
I mounted it with a bit of velcro that was handy. Though I later realized that the velcro covered up the LED's on the RX making debugging harder and it tended to pull the other end of the unit up. Plus I'm nervous about velcro in general, I've broken quite a few velcro straps on the wood quad and twitchity already:
The RX connects with just 3 wires, power, ground and PPM. The first three on the naze. Super simple to wire up. Don't forget to do a "feature PPM" and then "feature" to make sure only PPM is active in the Naze CLI to activate PPM input. I added a drop of hot glue to protect the wires here as well:
It should in theory be ready to fly now! All the minimal requirements are hooked up...well, except a battery cable and battery strap - not to mention battery itself:
But I don't want to try and fly with it like that - the naze is far too exposed. And given how the maiden(s) ended up going it's a good thing I opted to install the upper deck for protection first:
I also installed the mobius mount just so I wouldn't loose it. I thought about leaving it off so it wouldn't get damaged in an accident, but decided there was bigger risk of me loosing it than me damaging it - that may or may not have been a good call:
Since it's about ready for software tweaks and test flying I tried to grab a few glamour shots since it will probably never look quite this clean again!
Out of curiosity I got a weight of it ready to fly minus battery, battery strap, and battery cable:
One note: I do plan on replacing the stock orange openLRS antenna which is really really horrible. I'm going to make a Vertical dipole that will hang off the back similar to what the VAS/StoneBlue guys have been running on their 250 H quad builds lately. Just need to talk to my friend the bike geek about getting some bicycle brake cable to make it from
Next I hooked it to the computer and did some initial setup on the Naze. Specifically I did the "feature PPM" I knew I needed, I also enabled "feature failsafe" and changed the failsafe variables to:
failsafe_delay = 10
failsafe_off_delay = 10
failsafe_throttle = 1200
failsafe_detect_threshold = 985
I have my openLRS set to drop PPM completely when it looses signal which drops the signal well below 985
I didn't do any other changes at this point. I thought I took a look at the 3D copter orientation deal in baseflight config and confirmed it was reacting correctly...which is why I totally forgot about doing "align_board_yaw = 90" at this point.
Next I went to confirm that I had the motors wired right. I may have implied in my last post that this was done already but honestly I couldn't do it yet since I didn't have a power cable yet! So that was next.
