#include <AirComms.h>
#define PWR_LED_PIN 13
#define PITCH_COMMAND 0
#define ROLL_COMMAND 1
#define YAW_COMMAND 2
#define THROTTLE_COMMAND 3
#define AUTOPILOT_TOGGLE_COMMAND 4
#define LIMITER_TOGGLE_COMMAND 4
#define LANDING_GEAR_TOGGLE_COMMAND 5
#define FLAPS_TOGGLE_COMMAND 5
#define PITCH_ANALOG_PIN 3
#define ROLL_ANALOG_PIN 2
#define YAW_ANALOG_PIN 0
#define THROTTLE_ANALOG_PIN 1
#define PITCH_RATE_PIN 0
#define ROLL_RATE_PIN 1
#define YAW_RATE_PIN 2
#define AILERON_OFFSET 0
#define ELEVATOR_OFFSET 0
#define RUDDER_OFFSET 0
#define THROTTLE_OFFSET 0
#define THROTTLE_MAX 170 //full throttle
#define AILERON_MAX_HIGHRATES 320 //roll left
#define ELEVATOR_MAX_HIGHRATES 360 //nose up
#define RUDDER_MAX_HIGHRATES 330 //nose left
#define THROTTLE_MIN 50 //no throttle
#define AILERON_MIN_HIGHRATES 230 //roll right
#define ELEVATOR_MIN_HIGHRATES 220 //nose down
#define RUDDER_MIN_HIGHRATES 210 //nose right
#define AILERON_MAX_LOWRATES 325
#define ELEVATOR_MAX_LOWRATES 350
#define RUDDER_MAX_LOWRATES 292
#define AILERON_MIN_LOWRATES 289
#define ELEVATOR_MIN_LOWRATES 264
#define RUDDER_MIN_LOWRATES 264
#define THROTTLE_MIN_ADC 35880
#define AILERON_MIN_ADC 35300
#define ELEVATOR_MIN_ADC 36620
#define RUDDER_MIN_ADC 37330
#define THROTTLE_MAX_ADC 61220
#define AILERON_MAX_ADC 60180
#define ELEVATOR_MAX_ADC 62300
#define RUDDER_MAX_ADC 62170
//create instances of the AirComms class
AirComms commandsRadio;
AirComms telemetryRadio;
* Command Array Anatomy:
* Index Number - Command Type - Command Format
* 0 - pitch - 16-Bit Analog
* 1 - roll - 16-Bit Analog
* 2 - yaw - 16-Bit Analog
* 3 - throttle - 16-Bit Analog
* 4 - Autopilot Toggle (MSB) - 8-bit Boolean
* - Pitch/Roll Limiter Toggle (LSB) - 8-bit Boolean
* 5 - Landing Gear Toggle (MSB) - 8-bit Boolean
* - Flaps Toggle (LSB) - 8-bit Boolean
* 6 - Unused - Unused
* 7 - Unused - Unused
* 8 - Unused - Unused
* 9 - Unused - Unused
* 10 - Unused - Unused
* 11 - Unused - Unused
* 12 - Unused - Unused
* 13 - Unused - Unused
* 14 - Unused - Unused
* 15 - Unused - Unused
* 16 - Unused - Unused
* 17 - Unused - Unused
* 18 - Unused - Unused
* 19 - Unused - Unused
* Telemetry Array Anatomy:
* Index Number - Telemetry Type - Telemetry Format
* 0 - Unused - Unused
* 1 - Unused - Unused
* 2 - Unused - Unused
* 3 - Unused - Unused
* 4 - Unused - Unused
* 5 - Unused - Unused
//structs to handle control surface commands
struct controlSurfaces
byte command_index;
byte analog_pin;
byte rate_pin;
uint16_t _offset;
uint16_t high_rates_surface_max;
uint16_t high_rates_surface_min;
uint16_t low_rates_surface_max;
uint16_t low_rates_surface_min;
uint16_t ADC_max;
uint16_t ADC_min;
struct controlSurfaces ailerons
ROLL_COMMAND, //command_index
ROLL_ANALOG_PIN, //analog_pin
ROLL_RATE_PIN, //rate_pin
AILERON_OFFSET, //_offset
AILERON_MAX_HIGHRATES, //high_rates_surface_max
AILERON_MIN_HIGHRATES, //high_rates_surface_min
AILERON_MAX_LOWRATES, //low_rates_surface_max
AILERON_MIN_LOWRATES, //low_rates_surface_min
AILERON_MAX_ADC, //ADC_max
AILERON_MIN_ADC //ADC_min
struct controlSurfaces elevator
PITCH_COMMAND, //command_index
PITCH_ANALOG_PIN, //analog_pin
PITCH_RATE_PIN, //rate_pin
ELEVATOR_OFFSET, //_offset
ELEVATOR_MAX_HIGHRATES, //high_rates_surface_max
ELEVATOR_MIN_HIGHRATES, //high_rates_surface_min
ELEVATOR_MAX_LOWRATES, //low_rates_surface_max
ELEVATOR_MIN_LOWRATES, //low_rates_surface_min
ELEVATOR_MAX_ADC, //ADC_max
ELEVATOR_MIN_ADC //ADC_min
struct controlSurfaces rudder
YAW_COMMAND, //command_index
YAW_ANALOG_PIN, //analog_pin
YAW_RATE_PIN, //rate_pin
RUDDER_OFFSET, //_offset
RUDDER_MAX_HIGHRATES, //high_rates_surface_max
RUDDER_MIN_HIGHRATES, //high_rates_surface_min
RUDDER_MAX_LOWRATES, //low_rates_surface_max
RUDDER_MIN_LOWRATES, //low_rates_surface_min
RUDDER_MAX_ADC, //ADC_max
RUDDER_MIN_ADC //ADC_max
struct controlSurfaces throttle
THROTTLE_COMMAND, //command_index
THROTTLE_ANALOG_PIN, //analog_pin
0, //rate_pin
THROTTLE_OFFSET, //_offset
THROTTLE_MAX, //high_rates_surface_max
THROTTLE_MIN, //high_rates_surface_min
0, //low_rates_surface_max
0, //low_rates_surface_min
THROTTLE_MAX_ADC, //ADC_max
THROTTLE_MIN_ADC //ADC_max
//array to identify which datafields need to be sent to the plane
bool commandsArray[AIR_DATA_LEN] = {false};
//analog pin assignments
const byte yawPin = 0;
const byte throttlePin = 1;
const byte rollPin = 2;
const byte pitchPin = 3;
//loop total delay in ms
const byte delayTime = 10;
//variables for control surface values
unsigned int pitchValue = 0;
unsigned int rollValue = 0;
unsigned int yawValue = 0;
unsigned int throttleValue = 0;
void setup()
//turn on the Teensy PWR LED
pinMode(13, OUTPUT);
digitalWrite(13, HIGH);
//setup rate switch inputs
pinMode(PITCH_RATE_PIN, INPUT_PULLUP); //pitch rates
pinMode(ROLL_RATE_PIN, INPUT_PULLUP); //roll rates
pinMode(YAW_RATE_PIN, INPUT_PULLUP); //rudder rates
//take analog readings at a resolution of 16-bits
analogReadResolution(16);
//initialize serial ports
Serial.begin(2000000);
Serial4.begin(115200); //3DR radio
Serial5.begin(9600); //XBee radio
//initialize radios
commandsRadio.begin(Serial4);
telemetryRadio.begin(Serial5);
void loop()
//DAQ from joystick/switches
updateCommands();
/*Serial.print(commandsRadio.outgoingArray[0]); Serial.print(" ");
Serial.print(commandsRadio.outgoingArray[1]); Serial.print(" ");
Serial.print(commandsRadio.outgoingArray[2]); Serial.print(" ");
Serial.print(commandsRadio.outgoingArray[3]); Serial.print(" ");
Serial.println();*/
//send data to plane IFC
sendData();
//wait for IFC to "catch up"
delay(delayTime);
void updateCommands()
//read and map joystick data
//mapping normalized to max and min joystick values
updateCommand(ailerons);
updateCommand(elevator);
updateCommand(rudder);
updateCommand(throttle);
return;
void updateCommand(controlSurfaces controlSurface)
//value to be sent to plane
uint16_t commandValue = 0;
//read the analog voltage of the potentiometer
uint16_t analogValue = analogRead(controlSurface.analog_pin);
/*Serial.print("Command_Index: "); Serial.println(controlSurface.command_index);
Serial.print("ADC_min: "); Serial.println(controlSurface.ADC_min);
Serial.print("Analog: "); Serial.println(analogValue);
Serial.print("ADC_max: "); Serial.println(controlSurface.ADC_max);
Serial.print("high_rates_surface_min: "); Serial.println(controlSurface.high_rates_surface_min);
Serial.println();*/
//throttle is processed opposite of all other commands
if(controlSurface.command_index == THROTTLE_COMMAND)
//convert to a servo command format
commandValue = map(analogValue, //value to be mapped
controlSurface.ADC_min, //input minimum expected value
controlSurface.ADC_max, //input maximum expected value
controlSurface.high_rates_surface_min, //output minimum value
controlSurface.high_rates_surface_max //output maximum value
) + controlSurface._offset; //add the offset (bias)
else
controlSurface.high_rates_surface_max, //output maximum value
controlSurface.high_rates_surface_min //output minimum value
commandValue = constrain(commandValue, //value to be constrained
controlSurface.high_rates_surface_min, //minimum value
controlSurface.high_rates_surface_max //maximum value
Serial.print("Value: "); Serial.println(commandValue);
Serial.print("high_rates_surface_max: "); Serial.println(controlSurface.high_rates_surface_max);
Serial.print("_offset: "); Serial.println(controlSurface._offset);
Serial.println();*/
//set the respective commandArray index to true so that the servo data will be sent to
//the plane
commandsArray[controlSurface.command_index] = true;
//update the AirComms out buffer
commandsRadio.outgoingArray[controlSurface.command_index] = commandValue;
return;
void sendData()
//send commands to the plane
commandsRadio.sendData(commandsArray);
//reset boolean array
resetCommandsArray();
return;
void resetCommandsArray()
for(byte i=0; i<AIR_DATA_LEN; i++)
commandsArray[i] = false;
return;
