Did you see the Bronco pusher I had posted earlier in this thread, never had any of the issues this guy experienced. There are a flight vid or two in here as well.
I actually used the old emax C pack motor and not the Rimfire and it pushed it fine, as you can tell by the vids. I used a 2200 3s all the way up in the front to get balance but that would be the lightest I would go for slow flight, any faster and you would want to either use a larger battery like a 3000 3s or more, or lengthen the nose.
Ya I have to setup dual rates on it yet, a little too twitchy. I was hoping it would be bit slower. I'm going to try flaperons on it yet, just need to program it as the aileron servos are connected individually.
Half of the weight is electronics so going to smaller motors and ESCs I feel would be a big help but I'm not going to buy anything specifically for this.
Battery was pretty much at its minimum limit after 7 minutes. I'm going to try 2 batteries and see how it flys.
Next step is add the GoPro to the plane.
The motors being in the back of the plane forced me to mount the 2200 right in line with the front of the battery tray, plus a bolt with a couple nuts taped and glued to the bottom of the tray just to get a level balance on the suggested CG point. I like a little more weight in the nose to move the CG about a half inch forward so it doesn't pitch up as much under throttle. If you mounted a GoPro up front off the nose would that be to much nose weight being your two motors are ahead of CG?
Yes I had a challenge getting the CG right with the Explorer too, I also had to add nose weight.
With my Bronco that isn't a problem, the the 2200 3s is about 3.5" back from the nose, and there's a fair bit more room behind it as well, so lots of wiggle room. I haven't tried yet but I'm sure I won't have a problem balancing the plane regardless of where I put the camera.
Got a few flights in with the camera on the back of the fuse today. I'd really like to smooth out the flying a bit, I'm sure FPV would help that out. It's hard to tell if the plane is tracking level when it's way up there. I took it easy and as smooth as I could for the first few minutes then had some fun.
I’m going to be building a night flyer sometime before Flitefest, and I think Something no like @Sero did would really fit the ticket. I’d also like to put FPV on it as well.
