you guys have built some nice Explorers......
my grankids and I built one but they took it home with them before I could do any testing with wing loading and battery payload
Im about to build project with an Explorer fuse, use a bit larger Armin style wing with carbon fiber spars, carbon fiber tail booms to build a box tail...basically a home built FPV SkyHunter....caddix tarsier 4K video cam on a 2 axis pan & tilt gimbal and 2 other fpv cams run by 3 channel cam switch, 1Watt TBS Unify Pro32 VTX, R9M long range gear, Frsky variometer, Frsky current sensor, Tarrot OSD, and a zohd Kopilot FC with RTH
I have various battery choices, however I have quite a few 5000Mah in 3S & 4S that I would really like to use for maximum flight time this rig is to be used at work to video my livestock on several properties, they are all less then 4 miles away by air but 8-9 miles away from home by road and why I want flight time. I need to circle around the properties checking/counting livestock by video, its going to save me a ton of time, its a FUN way to work and I can write one plane off on my taxes
I built a versa wing prototype to test this gear out and was thrilled with the equipment, but realize I want a much larger air frame for both battery capacity and better handle the 7-10mph afternoon winds
I have several ESC & Motor choices to make this project work and my first selection to try out for slow fly long range FPV flights is a slow, low KV 3433 840kv Motor that can swing a big enough prop between the tail booms and make enough thrust to carry the scaled up plane and big battery I want to use
I have read a couple guys have run 2-3s 2200 mah in parallel so I dont think I need to scale this project up very much to use the 5000mah batteries I have.
Im thinking a 60" sport style wing slightly increase the chord as compared to the explorer wing should carry the load....the batteries are going to be tight but will fit, I may scale up the fuse 20-30%
I have all the parts and pieces but the darned carbon fiber tubes which means I cant begin the build till I get them and tracking shows them sitting in the same spot for 10 days now....... apparently they are in New York USPS quarantine?
whats the biggest battery you guys have tried in the Explorer?
