EZ Pack Plans Index
Mark408
Tip for others scratch building with the EZ Pack: Remove the paper, and sand down an airfoil for the wings and stabilizers! It reduces weight and drag and generates more lift. If its flimsy then a 1-2 mm carbon rod is good for a spar.
Jeremiah M
EZ Pack Plans
Designs by me:
Includes:​
  • EZ Bip
  • EZ RazorCrest
  • EZ DLG
  • EZ F-16
  • EZ F-18
  • EZ F-82
  • EZ F-4
  • View attachment 201774
  • EZ Blackbird and SR-71
  • EZ T-38
  • EZ FW-226
  • EZ ME-262
  • EZ JU-87
  • EZ Piper Seneca
  • EZ X-29
  • EZ Snow Skimmer
  • EZ Freezer Burn
  • EZ Cessna Skymaster
Plans Here
Designs by @Addicted
Includes:​
Plans Here
Designs by @Aviator08
Includes:​
  • EZ A-10
  • EZ Bipe
  • EZ X-Wing
  • EZ Glider
  • EZ Corsair V2
  • EZ P-40
  • EZ Piper Cherokee
Plans Here
Designs by @AgentC
Includes:​
Plans Here
Designs by @SP0NZ
Includes:
EZ Intruder: Full and Half Sheet Plans
Designs by @FlyinAgain
Includes:
  • EZ Bird of Prey w/ Canard
  • EZ Bird of Prey
  • EZ Old Fogey
  • EZ USS Reliant V1.1
  • EZ USS Reliant V1
  • EZ Sophisticated Lady
Plans Here
Designs by @rickp
Includes:
  • EZ F7F
  • EZ F7F Skins
Plans Here
I will add some more pictures later
What size should these be printed out in ?
AgentC
Here's the Resource Page for the EZ Sparrow.
Enjoy!
Mark408
Any interest for a EZ power pack version of this? It's a small F111 Aardvark glider with a swing wing. It glides really nice and slow when extended, and flies fast when retracted. The plane is made of peeled foamboard with the airfoil being cut and sanded down.
i built the ez raptor 3 times already and all three times i launch it it does a roll if i recover from that then it flies well for a little bit then does another flip on the 2nd version i built it just constantly did barrel rolles any ideas why this is happening
GliderBuilder
can you attach a picture?
the extra wires are the lights
also my first and 3rd version flew well in the begining and then after a few crashes they started doing rolls even though i checked to make sure nothing was bent or out of shape
also i modified it to only have 2 middle pieces of foam not 3 maybe thats the problem
AgentC
Ah. Whenever I've had models roll, I just adjusted the trim/elevators until it eventually levelled out.
Alternatively, have you tried chucking the electronics into a different model to confirm which (model or electronics) is the cause of the hassle?
AIRFORGE
Make It Fly!
on this version it rolls right i cant remeber on the other ones
Other than replacing a faulty motor, esc, etc., you can try locating the battery to the bottom of the fuse, but I don't think that will make a huge difference.
It should be noted that the EZ pack planes should always be flown with at least ~15% to ~20% throttle for the stabilizer to work properly.
bangoods has these motors though the ones i bought were slightly smaller than the original one for the 3ch though they still worked. though that was my fault since i didnt measure im sure they have the bigger ones too. the 2ch one i think has slightly smaller motors. the propeller can also be bought at bangoods and for those of you wondering bangood sells the 3ch control board for 13.99$ since you can no longer get them from flite test
