Alrighty folks. Even before I was a guest on the new FT Community cast I had been getting this question. Since then I have been given the question nearly every day by a different person. Needless to say this is a topic that needs to be addressed in a public way.
So, I am going to go through this in a very detailed way. If you have questions SPEAK UP. There are no wrong answers and there are no dumb questions. At one point this topic was a black box for me as well. I will post some pictures as I do not have any specifically on-hand. So I am going to do this a bit off the cuff.
Materials:
Fiberglass cloth (lighter is better for finish work but heavier cloth is good for reinforcement but comes at a weight penalty)
Water Based Polyurethane (WBPU)
some sort of brush
Gloves (if you are that fastideous. You are using a water-based product so cleanup is fairly easy)
wax paper or some sort of drop cloth that you really do not care about
A word on fiberglass cloth:
Lets get the sourcing bit out of the way: Thayercraft
So different weights produce different finishes. The heavier the cloth the heavier the finish and the more filling you will have to do and more filling means more weight. It also adds strength so you have to work a happy balance. THe Volan cloth takes compound curves much better so for fine finish work use it where you can. Again, if its a finish layer, use the lightest weight (0.56oz/yd.^2). If were to strip off the paper and replace it with glass I would go with 0.73 or 1.43.
Ok, So start with your raw foam part that has been pre-cut to size. Dry peel off the paper from BOTH sides. If you dont, the foam will curl and it will not be flat. Repeat, PEAL ALL THE PAPER OFF.
I'm using Bondo brand cloth here to show the weave. This is STUPID heavy stuff reserved only for a combat-style airplane. Mostly this is used for auto body or repairing a kayak.
To the point... cut your cloth out to cover over the edges of your part.
Apply WBPU to the foam first... one side only. Place your cloth on top and smooth it out with your hand. Then apply more WBPU working it into the cloth. The picture shows dry cloth and wet. Bottom is dry. You don't have to go super crazy. You will likely use less WBPU than what you are seeing here. Heavier cloth requires more WBPU to wet out (increasing weight).
You can se I'm using an old crummy foam brush to apply. This is fully wet. Now to let it dry.
Drying can be done over a length of time or accelerated. My preference is using Hot summer days. The radiant heat and UV light from the sun will dry the WBPU out in just a couple of minutes. Since its colder here, I used my wife's hair dryer on high heat, low fan. Keep in mind you are using foam here. DO NOT use a heat gun. You run the risk of melting your foam. It took me about 5-8 minutes of constantly moving the hair dryer to get it dry.
Turn the piece over with the glass face down and trim the excess with a knife. The other way is even easier. For lighter cloths you can simply use 220 grit sand paper along the edge of the glass. It will sand right through it on the hard corner and you can just remove the excess. Since my cloth is basically ropes its not an option for me in this example.
This is what you are left with. Turn the piece over and repeat for the other side.
After this you can cut your grooves, control surface score cuts, bevel hinges, all like the paper was there. The glass will be more stiff than the paper, but that's the point and why you are here reading this.
If you are going this far I would highly suggest picking up your hot glue gun and throwing it in your drawer. Use white gorilla glue. It will adhere better to the glass and provide a longer-lasting airplane. IF you are gluing glass surface to glass surface... use a toothpick or a nail to poke tiny holes into the glass to give the glue a place to expand into and grip the pieces better.
I also prefer aluminum ducting tape to hold parts together while drying. It will stick on dusty surfaces quite well and also prevent the glue from expanding where you do not want it to expand to.
Up next will be surface finishing.
Materials:
some sort of brush
