If you are thinking that you can just use the WBPU and BP mix to fill the weave... just stop. Do not try it. The problem is that the epoxy cures to such a smooth finish there is next to nothing for the WBPU to stick to. I've tried pre-sanding the surface and it still does not work well because you are trying to get the mix to stick to the little pits where the sanding will not get to.
So I've finally
been experimenting with fiberglass the past month or so. And some local guys are talking about doing some serious combat soon so think I may finally get around to building a bloody ripper
This thread has been very helpful in my experiments...but I was just re-reading it and saw the bit about not using WBPU/BP to fill the weave when using epoxy...and...well...I tried that and it seemed to work great for me.
But - the big difference is I used peel ply (well, <$2 per yard polyester dress liner fabric from walmart) when doing my laminations. This has a few benefits. First it soaks out excess resin from the cloth - most of what I've read about composites emphasizes that excess resin doesn't really add strength just weight. My friend with the composite full scale plane keeps getting reprimanded by his mentor that his layups are too rich and he's overdoing it with the resin. Though I've found conflicting info about just what an ideal cloth/resin ratio should be (mostly based on application since adding it on top of porus materials you loose a lot of resin into the base material.) Anyway, the other nice thing about using peel ply is that it leaves a rough surface that's perfect for the next layup if you're doing multiple layers...and seems to let WBPU/BP bond to it just fine.
I tried it on two panels, one covered in the 1.43oz thayercraft cloth and one covered in the 6oz bondo cloth. The bondo weave is a LOT harder to fill...but both of them smoothed out quite nicely with the WBPU/BP on top of epoxy. I used two different epoxies as well...the Thayercraft cloth was done with some really nice MGS epoxy a friend gave me while the bondo was done with BSI 30 minute since it was the most economical I could find at a local store. No problems with the WBPU/BP adhering to either with no special surface prep.
So just thought I'd share that.
P.S. - I also figured all this experimenting would be good practice to start getting used to epoxy/FG since I'm really itching to finish that plans built
balsa RV-3 I started 3 years ago and really need to make more progress on!
