First RC build ever - Tricopter, need help from expirenced builders
Hi guys and girls
First off, i'm all new to this hobby (Was playing Airsoft, but broke my leg badly so now i can't play), but I have been following flitetest on youtube for a year or so and read almost all possible threads here and on other sites and now i have set my mind, to build a tricopter.
EDIT: just adding that I've already calculated my flight time and it should be around 8-10 minutes
I really need some one to tell me if this setup will work. Looking for about 8+ minutes of flight time and ready to put on some FPV when i get the money for that part of the build
. also i will list all parts i will buy and how many, so pleas tell me if i'm missing something or should change some parts
(listed with the most essential parts first)
I'm not new to electronics, and building stuff, also programming (Arduino) isn't new either.
I have thought about the props and i choose to use CW and CCW
My controller will be a Spektrum DX8i, and since i live in Denmark i will be buying it from a local shop
Base Parts:
- Turnigy Talon Tricopter (V1.0) Carbon Fiber Frame
http://www.hobbyking.com/hobbyking/..._Talon_Tricopter_V1_0_Carbon_Fiber_Frame.html
- Hobbyking KK2.0 Multi-rotor LCD Flight Control Board
http://www.hobbyking.com/hobbyking/...2_0_Multi_rotor_LCD_Flight_Control_Board.html
- Hobby King Quadcopter Power Distribution Board
http://www.hobbyking.com/hobbyking/...King_Quadcopter_Power_Distribution_Board.html
- 3 x HobbyKing 30A BlueSeries Brushless Speed Controller
http://www.hobbyking.com/hobbyking/...0A_BlueSeries_Brushless_Speed_Controller.html
- 3 x NTM Prop Drive Series 28-30A 750kv / 140w
http://www.hobbyking.com/hobbyking/store/__16229__NTM_Prop_Drive_Series_28_30A_750kv_140w.html
- 3 x NTM Prop Drive 28 Series Accessory Pack
http://www.hobbyking.com/hobbyking/store/__16719__NTM_Prop_Drive_28_Series_Accessory_Pack.html
- 3 x Slow Fly Electric Prop 1045 SF (4 pc - Green)
http://www.hobbyking.com/hobbyking/store/__22448__Slow_Fly_Electric_Prop_1045_SF_4_pc_Green_.html
- 3 x Slow Fly Electric Prop 1045R SF (4 pc - Green Right Hand Rotation)
http://www.hobbyking.com/hobbyking/...1045R_SF_4_pc_Green_Right_Hand_Rotation_.html
- TGY-306G-HV High Voltage Ultra Fast/High Torque MG Digital Alloy Cased Servo 3.7kg / .05sec / 21g
http://www.hobbyking.com/hobbyking/...igital_Alloy_Cased_Servo_3_7kg_05sec_21g.html
- Nylon XT60 Connectors Male/Female (5 pairs) GENUINE
http://www.hobbyking.com/hobbyking/...0_Connectors_Male_Female_5_pairs_GENUINE.html
- 4 x Turnigy Pure-Silicone Wire 16AWG (1mtr) Red
http://www.hobbyking.com/hobbyking/store/__9681__Turnigy_Pure_Silicone_Wire_16AWG_1mtr_Red.html
- 4 x Turnigy Pure-Silicone Wire 16AWG (1mtr) BLACK
http://www.hobbyking.com/hobbyking/store/__9680__Turnigy_Pure_Silicone_Wire_16AWG_1mtr_BLACK.html
Extra:
- Wireless 9 in1 Simulator Adapter
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=24613
- Turnigy Heat Shrink Tube 50mm BLACK (1mtr)
http://www.hobbyking.com/hobbyking/store/__10430__Turnigy_Heat_Shrink_Tube_50mm_BLACK_1mtr_.html
- Scorpion Lipoly Lock Strap 205mm (Small) x 3
http://www.hobbyking.com/hobbyking/store/__17410__Scorpion_Lipoly_Lock_Strap_205mm_Small_x_3.html
- On Board Lipoly Low Voltage Alarm (2s~4s)
http://www.hobbyking.com/hobbyking/store/__18987__On_Board_Lipoly_Low_Voltage_Alarm_2s_4s_.html
- Lithium Polymer Charge Pack 25x33cm JUMBO Sack
http://www.hobbyking.com/hobbyking/store/__4364__Lithium_Polymer_Charge_Pack_25x33cm_JUMBO_Sack.html
- Hobby King Discovery Buzzer
http://www.hobbyking.com/hobbyking/store/__14521__Hobby_King_Discovery_Buzzer_.html
- 10CM Male to Male Servo Lead (JR) 26AWG (10pcs/set)
http://www.hobbyking.com/hobbyking/...e_to_Male_Servo_Lead_JR_26AWG_10pcs_set_.html
- Turnigy Receiver Controlled Switch (planned for LED)
http://www.hobbyking.com/hobbyking/store/__8833__Turnigy_Receiver_Controlled_Switch_.html
Spareparts for frame: (i know i'm going to crash)
- Turnigy Talon Tricopter (V1.0) - Carbon Fiber Tube (3pcs)
http://www.hobbyking.com/hobbyking/...n_Tricopter_V1_0_Carbon_Fiber_Tube_3pcs_.html
- Turnigy Talon Carbon Fiber Landing Gear (2pcs/bag)
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=22995&aff=930432
eirikso.com Talon Tricopter tail mod:
http://eirikso.com/2012/10/20/hacking-the-hobbyking-talon-tricopter/
- Thrust Bearing 3x8x3.5mm (2pcs/bag)
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=12131
- 3x30mm Sockethead Screw (10pcs/pack)
http://www.hobbyking.com/hobbyking/store/__18270__3x30mm_Sockethead_Screw_10pcs_pack_.html
- Hex locknuts M3 10pc
http://www.hobbyking.com/hobbyking/store/__6368__Hex_locknuts_M3_10pc.html
Flashing SimonK FW tools:
- USBasp AVR Programming Device for ATMEL proccessors
http://www.hobbyking.com/hobbyking/...Programming_Device_for_ATMEL_proccessors.html
- Atmel Atmega Socket Firmware Flashing Tool
http://www.hobbyking.com/hobbyking/store/__27195__Atmel_Atmega_Socket_Firmware_Flashing_Tool.html
Other Parts:
- 5.6mm x 12mm M3 Nylon Threaded Spacer (10pc)
http://www.hobbyking.com/hobbyking/store/__29530__5_6mm_x_12mm_M3_Nylon_Threaded_Spacer_10pc_.html
- M3 Nylon Nut (10pcs/bag)
http://www.hobbyking.com/hobbyking/store/__17853__M3_Nylon_Nut_10pcs_bag_.html
- M3X10 Nylon Screws (10pcs/bag)
http://www.hobbyking.com/hobbyking/store/__17849__M3X10_Nylon_Screws_10pcs_bag_.html
- 2 x TL-242 Thread Locker & Sealant Medium Strength
http://www.hobbyking.com/hobbyking/store/__10959__TL_242_Thread_Locker_Sealant_Medium_Strength_.html
- Polyester Velcro Peel-n-stick adhesive side V-STRONG (1mtr)
http://www.hobbyking.com/hobbyking/...eel_n_stick_adhesive_side_V_STRONG_1mtr_.html
- Peel-n-stick foam tape. 10x5inch 4mm thick
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=8999
Battery is a LiPo hardcase 11.1 4000 mAh 35C/70C (up to 3C charging) 311 grams
Thanks!
Hi guys and girls
Base Parts:
Extra:
Other Parts:
Thanks!
