FMS Corsair 800mm V2 Upgrade
OGnapkin
will the 800mm corsair v2 by fms fly on a 3s? also, what prop should I put on to make sure it doesn't draw too many amps?
F106DeltaDart
The stock prop works fine on 3S if you aren’t on full throttle the entire flight. If you plan to fly mostly at full throttle, an upgrade to a 25-30A ESC would be prudent. If you want to convert over to a 2 blade, I also found 8x6 works well for both 2S and 3S.
