Hi. We spoke lately on IG about designing Bf-110 and Fw's hatch so I thought I share what I've done so far. First of all - I used different material that wasn't easy to work with because it had tendency to crack when forming tight curves. It's all XPS underlay for floor panels, 5mm thick, everything that's outside is covered with transparent packing tape. I'm using polymer glue (something like uhu por) besides hot glue. I moved the servos forward but I don't think it changed much since long 0,8mm wire still weighs something and CG isn't moved too far forward. The AUW so far (without paint) is below 700g with old power pack C motor and 2200mAh (the good 'ol ft spitfire setup). I wasn't sure which fuse panel I should start with - now I know it should be the most rear panel to support stabilitators which would wiggle all the time and eventually break... After putting all panels in place the plane became very rigid. Only problem was the hatch, I tried to recreate what you've done and I think it went out pretty good. I marked the places where it would be and cut it out after glue dried. I don't make planes swappable so I got rid of this "shelf" inside fuse - the battery lays on bottom of the internal fuse. The wing went out very good, better than the fuse heh. Only mistake I noticed was the very front panel (not cowling) was a bit too long - the loop was bigger than front former. I trimmed both sides by 1cm and it sat in its place just good. The next step will be using putty to fill any gaps, sanding and painting. Now I wish I made landing gear on this bird, even though catching it with hand is easy.
In conclusion - very good plans, the idea of internal and external fuse is very clever. I find your plans better thought out than ft master series plans and surely easier to adapt to materials that I've got. I think I'll make your P-47 someday soon when I get silver packing tape, but for now mosquito is on my bucket list.
Back to topic - thanks for sharing these plans guys, I hope you'll get recognized by RC community. You deserve it
