JakeTheSloth
Wingspan is 70cm. I have maidened it already. The tail was a bit twitchy but after reducing throws it flies very nice. I've bought gens 850mAh 3s 75c batteries because it was underpowered with old lipos. It still needs hatch, spinner and fairings to complete the look, not to mention paint job. As I said before - this design isn't mine, I just modified existing plans - that's not a problem for me if you refine the plans and release them as yours. You can also mention me as "helper" 😅
And as for the foam I'm using - I think the weight is reduced because it's not covered with paper at all. I only cover the pieces that are outside with packing tape. 3mm for mosquito sounds reasonable but I think P-47 should be made with 5mm all together to keep its sturdiness
