Hey all,
I wish I had people local to ask but as of yet have not run into anybody that is really doing any of this, so I hope the community will have an expert or two to make sure I am going in the right direction.
I am wanting to Fly FPV with an OSD, and be able to auto level, or possible auto pilot or RTH abilities. I don't want to do this all at once, but I want to know if the setup I have shopped for will be able to do this and if I have the right pieces and that they will work together.
I want to go one step at a time, but probably start off with the FPV, OSD. I'll worry about the other stuff once I have a much firmer grip on things such as RTH, Autolevel later. I have fairly limited flight time, but have had good success with the Old Fogey thanks to great suggestions on the board, and think my FPV platform I 'should' move to is the FT Explorer. I still need something fairly easy to fly, but large enough to support all the added gear. The gear package I think I should get is:
RunCam Split 2 FPV Camera FOV 130.
Am I on the right Track, am I in the correct Forum Group... Will this give me a good configurable setup in the end for a fixed wing aircraft? Any help or feedback much appreciated.
-NV
- The reason I want to use this is that I can get the FPV experience and a 1080P record experience all at once
- Do it so I don't need to add weight for a second camera, or put my go pro at risk of fatal damage...
- Is this a good idea or option?
- The reason I have chosen this is I like the multiple transmitter power choices and it supports OSD
- For eventual upgrade to GPS and RTH this is what I think I need
- This is the flight controller I think I want
- I don't know if I should use Betaflight or Cleanflight. Can I flash this board with Betaflight if I don't want to use Cleanflight
- Will my other boards etc work in both Beta and Cleanflight modes
-NV
