Aeos
Hey all, been awhile. So I've got a 9XR Pro tx with a frsky DJT module and D8R ii rx. They came together in a package, should be good to go, yes? Not so much. I've tried the binding procedure 3 times now, and it still just flashes red, and indication that it's still trying to bind, I believe.
Turns out Google is not so helpful for this hobby, and the MQC on facebook isn't responding to this one either. Sooo, not sure what to do here. Not sure exactly what the 2 little switches on the back if the module are supposed to be set at. Based off a youtube vid, they're supposed to be up..oh no, wait, they're supposed to be down...Idk, but either way it isn't working. Do I need to update the firmware on my tx? The instructions say I have to turn it on to PPM, which I thought it was, but for the life of me, can't figure out in any of the menus where I saw it at. Any 9XR peoples out there know?
My Naze issue might be directly related to the rx issue, but I'm not knowledgeable enough to know for sure. Whenever I plug in a battery, it just beeps constantly, and the green light flashes. Turned off voltage alarm, as I seen that was an issue for someone else, but it still continues to beep and flash.
Are the above issues directly connected? The Naze didn't start the beeping until I soldered on the rx. The video shows what the Naze is doing. I've read that the beeps are supposed to be code you see in Clean Flight, but I haven't a clue as to what it's a code for. This is my first go with Clean Flight, so any help would be appreciated.
