FT-22 Raptor - PROJECT
fliteadmin
Administrator
Admin
If you've been with us for a while you might recognize this beauty, but with a few new additions. Say hello to the FT-22 Raptor!
We based this off our original F-22 design (above) but with all the improvements you could ask for.
The front scoops created by the belly plate provide excellent cooling for your electronics, and it looks cool!
The nose is actually made completely from foam which drastically increases the durability. No more wrinkled poster board noses!
There is plenty of space in the cockpit for your battery or whatever else you guys might want to throw in there.
To reduce rod flexing, Josh noched out a small piece of foam attached to the side plate and ran the rod through. No flex, no hassle!
To go along with our decal kits we have new bigger logos color matched and ready to go!
Also, the first 250 people who buy a speed build kit will also get a FREE small decal. Our thanks for being awesome!
Even though this plane is technically a jet, don't let that intimidate you! It's extremely easy to build and it will only go as fast as the motor you put in it.
The FT-22 boasts great high-alpha, and acrobatics are no problem.
As always, fly with a friend (or three)!
Sadly, we still haven't figured out how to make the planes tree-proof.
As always, we want to thank you guys for supporting Flite Test. We wouldn't get to do what we do if it weren't for your help.
As always we have free plans and a build video on the way!
Ron B
@ Bitogre I went to the store and it was listed as beginner to intermediate.
Ron B
Who doing the flying around the trees at the end of the video?
Nice flying
Okie
Flite Test Aviatrix
I thank Bixler was flying at the end seems like something he would do .
and one of my planes are in a tree too so when you figured out how to make the planes tree-proof let me know my planes love to play in the trees
lolingbanana
so wish there was a uk store, would love to build this and get back in to the hobby, but over $40 for shiping is daylight robbery but i know you are not to blame for that, its just what things cost these days.
jhitesma
Some guy in the desert
I had a feeling this was coming...I just printed some F22 plans off rcgroups about two weeks ago but haven't had a chance to start building yet. Looks like I'll hold off just a little longer and switch to the FT plans - looks a lot nicer!
eagle4
lolingBanana, there will be free plans available
I wonder what battery its setup to use.
Also if they used a KFM2 airfoil it should produce more lift, which would be great for some fpv flying.
I wonder if they tried tilting down the shoulders of the wings just a little bit, this would make the wing have a little bit of camber, thus increasing lift. The real F22 had this, it was a semi lifting body. just a thought, as this may or may not work.
Bladezx2
Electronics Requirements
Got this from the Store page for the plane.
Recommended electronics:
MOTOR (Option 1) - "Blue Wonder" 2712-12 24g
MOTOR (Option 2) - Suppo 2208/14 1450kv Brushless Motor (Park 370 equiv.)
MOTOR (Option 3) -"THE BEEF" (Motor only) GT2215/09 70g
Servos (Option 1) - Hextronic 9 Gram Servo
Servos (Option 2) - Suppo SP-90 9g Micro Servo
ESC (Option 1) - TURNIGY Plush 25amp Speed Controller
ESC (Option 2) - Suppo 18A Brushless ESC
Battery (Option 1) - Turnigy 500mAh 3s 20C Lipo Pack
Battery (Option 2) - Turnigy 1000mAh 3s 20C Lipo Pack
Battery (Option 3) - Turnigy 1300mAh 3s 20C Lipo Pack
Prop (tractor) - Slow Fly 9x4.7 prop
Prop (pusher) - 8x6 Slow Fly prop
I noted rod flexing problem, possibly this is the answer to the problem I'm having with a delta combat plane which flys well a half throttle but when I hit it all h*** breaks loose,I though it might be fuse flexing but could be a combination of the two
Flynn
I has the exact same issue, then retired the Delta.
Steve Bowman
Great build, the F-22 went together in 2-3 hours. The maden flight was great, a little trimming and away we go.
Love the plain and so do a lot of other stander byers..
BLewis
I built mine and used slightly larger wire (.055") for the control rods and put them in a coffee stirrer and used an additional piece of foam with a slot in it to secure the stirrer. Works great and does not flex.
also another tip: I did minwax the plane and sprayed it with thinned craft paint. I did get it a little heavy (did not cover very well) the weight is ok, but it warped the wings and had to give it quite a bit of aileron trim. Will not use craft paint again.
