I just got back from the field I frequent where there is the runway I mowed, it isn't very smooth as far as son goes, patches of grass mixed with areas of 1-2" of snow. It is a bit breezy as well so lining up the flight path for approach was difficult, even into the wind, I just need more time with it. I probably wouldn't have been able to do it with the Sportster either, which has more weight and a shorter wingspan then the BW. I will wait till later this evening to try again, maybe the wind will die down. I did do some practice on controlling the plane with half flaps, seen a little progression there, but I also saw some surprises as well. With the flaps deployed there was a noticeable reduction in roll authority even though the ailerons are full wing, probably because the flaps block 1/3rd of the control surface.
In the air I did find the for the surface area of the ailerons the roll was somewhat anemic compared to planes with shorter wingspans but the large rudder took care of that and snapped it to attention.
On my last landing/controlled crash lol, I noticed a weak spot in the TE of the wing where the elastic bands wrap over. i did use a skewer to line the TE so the bands don't tear through but area just and inch and a half ahead where the TE of the bottom plate meets the top has developed a slight fold, propping up the back of the wing. This i will reinforce with pop sticks running parallel to the center line front to back. I wish I would have foreseen this in the build before folding the wing, I could have put it on the underside so it would be hidden. Don't matter though i will use a sharpie to color it black and keep on trucking.
I did do 3 rougher landing and I will say the gear, even though it nosed over every time du to uneven terrain and lack of skill, held up really well considering. There are a couple small stress wrinkles in the side just above one LG strut but I think it is just taking up a little slack in the airframe between the skewers and the pop stick reinforcement on the inside. Any thoughts or suggestions are welcome
Stay tuned
