Here’s what I’ve got so far.
I made took normal ft wing( other than the slight change with the ailerons and flaps) and peeled the paper off the inside instead of cut the score marks. Also, I didn't cut the double bevel in the LE of the wing - I removed a strip of paper about 1 centimeter thick from the marks that they have on the plan to show a bevel cut. I did this before removing the paper from anywhere else on the wing. Then using the table, I creased and molded the front section to get the curve I needed. Then I peeled the rest of the paper and molded that over. The end result is a very smooth and good looking wing! For the fuselage I made all the score marks for the cavities, but instead of removing the foam I removed the paper and then creased and molded the “fold.” On the bottom of the fuse you can see I did make a slight modification. I cut the bottom fuselage cover in half down the center and then grafted it into the sides of the fuselage so there would only be one seam running down the center on the bottom. It looks really good IMHO. Unfortunately the rear fuse piece ended up a tad bit bigger and then I glued the two rear pieces crooked so there is a bit of a gap...
But I’ll see if I can fill it in with a little glue or foam and make it less ugly. I really happy with how it’s turning out! I probably won’t be able to work on it more today cause I have to build a simple stick for a friend but hopefully I can start on the nose tomorrow!
