Hello folks
I am new here but not new to the hobby .Helis are my addiction, and planes I admire a lot. FT Storch's build videos got me questioning if I really know how to setup a radio for a well flying plane.. Again.. not new to radios .. I have a JR 9503 DSMX radio that i trust..But all planes i have built and crashed till now have been simple setups.. ailerons on Y harness, and may be flaps as another Y harness... and so on..
Josh seemed to want to use two seperate channels for the Ailerons on this Storch to use as flaperons. I honeslty dont know how to setup flaperons.. I know what it means, I see what it will do. But I wish I knew how to do it. NEver to late to learn, hence I need some help .. I have selected wing type "flaperon" in my radio.. was I supposed to do that?
Another thing.. in a stroke of genius I had, while building I had some extra hotglue that go onto the hinge of the elevator, so I thought.. hey I have a heat gun.. you know the rest.. well its not ruined, some foam inside melted, and I caught it quickly enoughh .. but if I wanted to replace just the elevator / rudder on this frame without having to build another new frame, is there a way to do it? how do yall faom builders do that cleanly?
anyway.. Radio question is more important, please let me know how to configure my JR 9503 with working flaperons. and any other tips and trick you know I should use. I am using the third servo horn hole and the recommended holes on the hinge horn on the control surface. what holes would you use?
I have flown planes before like I said, not a total noobie here.. But I realize I dont know all that is out there .. the more I know.. the more I realize I dont know ..
