Matthew Sanders
Ok, thanks. I'll be using a 2200 3sIt should fly better! I was running off a 1500 mah 3s
Haha - I love it. It’s great!So, do you like my signature?
Do I get PROPS for that? 😄Haha - I love it. It’s great!
I missed it until you mentioned it. That's funny!So, do you like my signature?
That will be better, as I had to add some nose weight to mine. Plus, It’ll give you linger flight times, as EDF’s really suck the power! I’d recommend setting a timer to 3 or 4 min. then landing and checking the voltage. @Headbang and @Hai-Lee could give you better tips I’m sure, since I’ve never used an edf myself. I’m just passing on what I’ve read.Ok, thanks. I'll be using a 2200 3s
No, unless you count the fan itself a prop! 🤣🤣😂😂Do I get PROPS for that? 😄
Ok, thanks! I'll set it to 3 and 1/2 minutes!That will be better, as I had to add some nose weight to mine. Plus, It’ll give you linger flight times, as EDF’s really suck the power! I’d recommend setting a timer to 3 or 4 min. then landing and checking the voltage. @Headbang and @Hai-Lee could give you better tips I’m sure, since I’ve never used an edf myself. I’m just passing on what I’ve read.
INVERTED like a BOSS. Nice maiden, flew awesome, almost floaty.I finally maidened the viggen! My friend launched me the first time and she had a mild lawn dart that made the nose a little dirty but that’s all. I left it out of the vid though. I have more footage I’ll edit and post later, including a lot of inverted flying. @BATTLEAXE you were right - you can totally do inverted with a kfm wing and it flies like a dream. My buddy who was with me also flew it and he was super nervous to fly it. I made him anyways😉 He was amazed at how well it flew! One thing is that in high alpha, it has a ton of wing rock so we were discussing adding wingtip plates and vortex generators. Overall a great plane and super easy to fly. My friend even said it may make a good trainer, so that shows how much he liked it.
You're correct, the build video says 10 degrees of pitch on the canard. That would be cool if someone tried to make the canards as elevators.INVERTED like a BOSS. Nice maiden, flew awesome, almost floaty.
I know the Viggen has a 10 or so degree of positive angle of attack in the canards, correct me if I am wrong, But I heard from others who have flown the Viggen and judging by you flight, it has a lot more roll then pitch authority. I am wondering how it would fly if the elevator was on the canards and the wing surfaces were just ailerons
As a 70mm edf, a 4s-6s 3300mAh is generally the sweet spot.That will be better, as I had to add some nose weight to mine. Plus, It’ll give you linger flight times, as EDF’s really suck the power! I’d recommend setting a timer to 3 or 4 min. then landing and checking the voltage. @Headbang and @Hai-Lee could give you better tips I’m sure, since I’ve never used an edf myself. I’m just passing on what I’ve read.
I watch a few vids on the engineering of plane designs once in awhile and I just thought of it when I watched @The Hangar maiden. I haven't heard of anyone doing it to the Viggen yet. I wonder if it would even out the roll/pitch ratio some. I myself haven't flown with canards beforeYou're correct, the build video says 10 degrees of pitch on the canard. That would be cool if someone tried to make the canards as elevators.
Thanks! You should try and seeINVERTED like a BOSS. Nice maiden, flew awesome, almost floaty.
Short answer "no". The canards are there to stabilize and there is no advantage to doing anything with them unless you have them adjustable to mix in with different flight conditions. The viggen flies great without modification. I did cut you a second wing to use as a doubler if you want for added strength.@Headbang do you think the elevators on the canards would work?
Thanks man, I appreciate it.Short answer "no". The canards are there to stabilize and there is no advantage to doing anything with them unless you have them adjustable to mix in with different flight conditions. The viggen flies great without modification. I did cut you a second wing to use as a doubler if you want for added strength.
So we'll have yet another viggen coming in the near future?! This is great!Thanks man, I appreciate it.
Oh yeah! The edf will be awesome! Just think landing in the snow and sending a spray of snow out of the back of the fan - that would be an epic sight!Possibly and it's an EDF as well. I am pretty excited about it. First jet
On a canard the foreplanes provide the same wing loading as does the main wing in level flight, (this is per unit area of course). If the area or the angle of attack of the canards is varied then the CG or balance point will be effected. The good thing about canards is that they are effectively stall proof in normal flight.@Headbang do you think the elevators on the canards would work?
