Junker/Reflex Flap attachment details
Below, find detailed photos from how I attached the second half of my reflex wing.
First lets cover what we're aiming for here.
Here's the plan design(again):
Understanding the goal here, let's go through how I line up and connect this wing-edge long flap mechanism:
Start by placing the 3rd standoff in, at the bend in the wing -where the pen is pointing. Closeup below
Remember this section is the elevator flap.
Line the piece up and 50% score on each side of the standoff and remove the foam
Glue the first segment on.
Before the glue cools, level out the flap to be parallel with the wing underside.
Now move on to the outer wing flaps (ailerons). line up the leading edge of the flap with the trailing edge of the wing and make your cuts.
Now glue. add enough so it remains soft while you push the standoff in and adjust
once all the standoffs are in, adjust so the top of the flap and bottom of the wing are parallel
look down the flap/wing to check the alignment before the glue cools.
Here it is installed. Note that every other vertical link to the flap goes through for the servo linkage.
Here's a picture of the mini-flap reflex mechanism. This is very precise and uses small forces, and may be suitable for smaller finer wire.
I hope this helps anyone interested on how to install the Junker flaps in, and get ready to link to the servos.
