That is a beautiful Plane! and a great video! It will be quite the screamer with the 6 other motors on the back.
I can't wait to put together the micro version with 3".
When you declared this project, I was concerned about the supports too. I thought you would just put a symmetrical airfoil around the CF tube spar that went through the larger outlet. (taper afterward). Then I was thinking that if you built it like the Giant FT A-10, and make a 3/4 ply ring the spar hooks to...
I have a project (Eldar cruiser) in mind like the SR-71 blackbird with a tube shooting through the structural spar, I was planning to set a number of 3/8' thick rings in the foam around the engine tubes to continue the spar. (and cross my fingers) but I have more work before I get there.
Great Job! I can't wait to build one of my own. (now you need a ton of red-faced Hydra troopers to "jump" out of it mid flight.
I definitely need some hydra goons to drop from the plane and be see if it can be used as a parasite mother ship lol. I'll honestly be looking into it.
I think the rings are the only real way to reinforce a tube that goes through the spar. I tried to do a simpler solution and threaded a paint stick through the edf tube. I think it would be enough for a smaller model but this thing is just way too large.
