Inq
I'm probably deluding myself again, but the FTFC23 Focke Wulf Ta 152H is taking way too much design time for it to get done this month. And... I've been following @telnar1236 's F-104 and Mig 21 builds. I have a couple of cheap 70 mm EDF's that I got on sale several years ago that have never been out of the box. All these thoughts have conspired to drive me to attempt to build and more ominously fly an EDF. My first thought was to just slap the EDF between two foam boards with the silhouette of the Crusader, pop on a FT style fold over wing and build it in one day.
Although @telnar1236 says the f-8 has some nasty habits in model form, I kind of have to... this is the plane my father flew in the Marines.
Well... famous last words. I then thought... I've been learning to curve the foam boards, let's try to at least round the body and still have a boxy silhouette nose. Then that gets into having to have some sections to hold the rounded shape. But, I can't put those in since that's where the air has to flow through. So... the project grew some more... 3D printed, aerodynamic formers. I started this morning at 9:00 am and this is where it stands now.
It turns out I can get pretty close to scale with one strait tube that does neck down, but it a basically a conic so only a 2D curving is required. I also can get the egg-shape cross section pretty close. I've designed the four fuselage stations to hold the proper cross sectional shape and have streamlined them inside to minimize duct drag. They're printing now.
From front to back, the first one will mount the nose. I may make the nose removable. It'll depend on where I need to put the battery to get a proper CG. The second and third stations will have the wing mounts for a removable wing (more in a moment). The last one mounts the EDF and tail cone. I'll take a stab at a 3D Printed nose as its got way too many 3D curves for my skills with foamboard. The jury is still out whether the tail cone will be foamboard based or 3D Printed. Likewise on the vertical stab. I plan on making the flying wings fly, but I'll make them elevons even though the F-8 only had them as an elevator. I hope not to need wing mounted ailerons.
Training Wheels
The wing will actually be two wings. I'll make one to scale of the F-8 with the 5° anhedral. But I also think I'll make a lot bigger one with less or no sweep and probably include some dihedral to help me transition to a faster EDF airplane. I'll make it so that the A.C. is in the same place on both wings so I don't have to change the C.G... and I'll use the same fuselage mounts. If I can get away without putting servos, ailerons and such... is should be a 10 second swap for when I get brave enough to use the F-8 wing.
Oh... no real wheels. Trying to keep it light, and simple for the FTFC23. It'll be a belly lander.
Training Wheels
