Introduction
This is my entry for the Flite Test Community March Madness Challenge (FTCMM). The goal of the challenge is to encourage designers and builders to finish designs and builds that they dropped or abandoned.
Update 23rd April, 2018 - Plans Added.
The attached file (at the bottom of the post) contains the following:
Tiled and Full PDF plans
Sketchup, DoubleCAD, and exported .DXF files.
PDF with the Fat Albert decals.
Background
This project started when a guy at our field, who knew I like to design and build planes, showed up with the remnants of a 250 size quad. It was basically a frame with four motors, four props, and four ESCs, and he asked if I could build a C-130 using the electronics from the quad. Although I had never thought about this plane as a build project, we soon agreed on some basic specifications for the build. Because he keeps his planes in his truck he wanted to keep the wingspan as short as possible. He had some wheels that I could use and we decided on including a steerable nose. Most importantly, he requested that the plane be painted as Fat Albert. For those of you who don’t know (and I didn’t before this build), Fat Albert is the C-130 used by the Blue Angels flight team as a cargo hauler and it also performs at the shows, demonstrating its Jet Assisted Take Off (JATO) capabilities.
The real Fat Albert in flight
The original plane flew well enough on her maiden but she had some nasty tendencies that made her drop like a rock on high bank turns. You can enjoy my walk of shame in this vid.
It seemed to be either a tip stall or general wing stall issue. I made some adjustments to the wing, thought I had her sorted, and painted her up.
Ah, she was pretty in those days
Again, she flew pretty well, but the modified wing still wasn’t up to the job and we suffered more crashes and/or really rough landings.
The second wing version was a little better but still needed to bring her in hot for landings or she would cartwheel.
Third time was a charm and the current wing works great. Here she is playing in the wind with a friendly Guinea
By this time the rest of the plane had taken a battering. The nose (the second) was totally wrecked, the tailfeathers had taken a beating on some cartwheel landings, and the fuse was beginning to disintegrate.
Looking and feeling a bit tired
I had put a reasonable amount of work into the plane at this stage and I really didn’t want to rebuild her. I knew there was some design changes that needed to be made and it had become one of those builds where I didn’t have the motivation to finish. I just wanted to fly what was left until it was dead. Of course, this meant my friend didn’t have the plane I promised him, and he has been quite patient.
So time to get back into the saddle, as it were, and get this job done.
Goals for the build.
In addition to meeting the requirements for the challenge, I want to re-work or fix the following items and as I complete them I will update the text below.
Fuse
(1) Add strength to the joints between fuse sections. The simple butt joint with hot glue approach works but it doesn’t last. Update 06Mar18: Designed a simple 12 sided insert to create a lip between the center and tail fuse sections. This should provide enough additional strength
(2) Test the possibility of using a 10 or 12 sided fuse (current version is 8 sided) to make the fuse more round without giving up too much strength while keeping the hollow tube build approach. [Update 02Mar18: Oops, the current model is already 12 sided (just shows how long since I looked at it carefully), so consider this done!]
(3) Add a cargo bay door (which will require more fuse strengthening). This will be a simply one piece door and not the two piece found on the full scale plane (or on really, really good models like this one...)Update 06Mar18: Cut a cargo door out of the mule which is approx 6 inches long and 3 wide. Thankfully the rear fuse section is strong an there was no notable impact on the structural integrity (gotta love gorilla glue!).
(4) Strengthen the wing mounts
(5) Design in the wheels as opposed to hacking them in as I did on the originalUpdate 09Mar18: Done - originally I had set the ground clearance too low in comparison to scale. The newer version might be a little high, but will negate the need to hack into the fuse for clearance (I hope!)
Tail Feathers
(1) Strengthen both the vertical and horizontal stabilizers, possibly using a double layer of foamboard [Update 02Mar18: Having checked again, looks like the VStab is solid. The Hstab only has issues at the tips, beyond where the wooden spar reinforcement ends, so the solution is a longer spar - no need to double up on the foamboard
(2) Do a neater job on the servos Update 09Mar18: Decided to mount the servos for the tailfeather a little further forward so that they are serviceable when the cargo door is open
Wing
(1) Make the nacelles a little smaller or more streamlined in shape Update 03Mar18: Nacelle design updated to be a little smaller and narrower. Closer to scale but not quite due to the constraints of fitting the motor.
(2) Increase the aileron area significantly (they are tiny on the current wing version and roll authority is not great). Update 20Mar18: Done
(3) Do a cleaner wiring job for the servos and motors and make the two-part wing assembly and associated wiring neater.Update 02Apr18: Done - totally re-worked the wiring to pull the ESCs into the fuse as opposed to living in the nacelles (which are smaller now and would make removing the motor and ESC really difficult
Specifications
Wingspan: 50 inches
Length: ~37 inches (depending on how battered the nose is)
Power: 4 x SunnySky x2204S-16 2300Kv motors wearing 5030 props and driven by 10A noname ESCs
All Up Weight: 34 ounces with a 2200mAh, 3S battery
DamoRC
Background
Fuse
Tail Feathers
Wing
Specifications
Wingspan: 50 inches
DamoRC
