I have no prior experience with drones other than a DJI mini 2.
The guardian can take a beating. Some how I managed to shear off one of the delrin screw heads, good thing they send extras. It is a real pleasure to learn on knowing that if it does crash(If you are new it will) you will still be able to fly it after, instead of waiting on new parts to arrive. I have been burning battery after battery on this thing for the last 4 days, and it is a blast. Make sure you have a good supply of batteries, you will not want to to stop flying once you start. It is decently acrobatic, and I have pulled off some rolls and loops with it, as well as smashed it into the ground and a few trees, but it still keeps kicking. I am also still on the first set of prop installed, thanks guys this thing is a blast to fly.
The only downfall was the build instructions or lack there off(I understand a video is being made), and having to track down the pin outs for all the components. Building was easy once all the info was located.
I would like to see the pin outs for the ANT AIO provided so we can access the built in betaflight OSD while flying. The color LED combos mentioned in the description for Channel, band and power do not match my camera. Mine are Green for Band, Red for Channel, and Blue for Power level.
You may also want to bind the Sat RX prior to connecting it to the Flight controller.
This is a duplicate of the review I am leaving on the store page. Cause why not.
