Now that it's indoor flying season I've had the chance to fly several airplanes at the hockey arena. The only one that doesn't handle the way I like is the Lancer. I have to keep the power on all the time. It doesn't glide very well. I flies like it's a little tail heavy with the power on and glides like it's nose heavy. I don't think it has enough wing for the added weight of the electronics.
I stripped off the film and split the wing at the center. Then I built a 6 inch center section.
The Guillow's plans have templates for all the ribs. I made the spars from 3/32" strips instead of 1/16".
The wingspan was increased to 30" from the original 24". There is more polyhedral than before too.
It's raining outside but I had to give it a couple of quick test glides. I taped the propeller gear so it doesn't spin and act as a brake. The results are promising. It glides much better and doesn't nose over. The next calm morning or indoor session I'll get to test it under power. I think it looks better proportioned with the longer wing.
