"AT-6 Texan" Herr Kit #114 Rubber Power to RC Conversion
TooJung2Die
Whoops. Reminds me of when I tried to glue servos in using thin CA. What's stopping you from just screwing them in?
I think everybody learns the CA and servos don't mix lesson. 😆 I cut the ears off the servos to make them fit better. Servos are working again. The only good thing about having to do something twice is you should be able to do it faster and make it better. No point posting another wing photo; repairs are complete and it looks no different. 😎
telnar1236
The plane looks great. That's too bad with the servos. Sealing the seams on the servos with a very thin layer of painters tape can help prevent these issues, and then you can mount them using a very judicious application of CA to save weight. I've never had any issues using that method.
danskis
Yep...I'll never use CA for servos again. It was medium CA but still....
Others in the club wrap their servos with painters tape.
TooJung2Die
Painters tape? That would make peeling it off in the future less of a hassle. 👍 I disassembled the stuck servos and easily removed the tiny blobs of glue that were binding the gears. While the servos were apart I used a toothpick to coat the gears with the excess grease you'll find clumped around the gear train. I used 'scotch' tape to seal the servos before gluing them back into the new servo trays.
All the major assemblies are sanded and ready to cover. Gussets were strategically added to the wing trailing edge. Balsa to mount the aileron control horns is added. Everything is taped together and the electronics are positioned inside to get a ballpark idea of where they need to go to achieve the correct CG without adding ballast.
The airplane is balanced on a piece of 1/4" square stock under the wing main spar. A 450mAh 2S battery slightly forward of the wing main spar got the balance just right. At this point, before covering and painting, it weighs 4.8 ounces.
Jon
TooJung2Die
The covering is finally going on. I'm using 1.5 mil standard document laminating film from laminator.com. Easy pieces first so I get used to this film and the best iron temperatures. That's the huge 500 foot roll of film I bought. I'll never use it up.
Doculam is perfect for delicate balsa frames. It shrinks gently. This is my covering tool kit. The bean bags are good for holding wings without breaking balsa.
Here's a trick I learned for using document laminating film. Leave plenty of excess film overhang and don't trim it until after the film has been shrunk tight. If there are wrinkles that don't shrink out you can apply the iron to the tacked down edge and pull out the wrinkle.
This first wing panel turned out smooth and wrinkle free. The excess has not been trimmed off yet. Crank up the heat so the film softens and it can be stretched over compound curves like the wingtip in the photo.
Jon
TooJung2Die
Wing is completely covered.
The covering film wrapped nicely over the wingtips. The top including the tips is covered with a single piece of film.
The wheel fairing is fitted and glued in place.
Bottom of the wheel fairing. The bottom balsa piece from the kit was not used. I couldn't see any useful purpose for having open holes for wheels that don't retract so I made the bottom closed up.
Jon
Jesse Dupreez
Jon
is that just like laminating pockets?
TooJung2Die
This fuselage was, by far, the most difficult covering job I've done to date. It took a week of working on it over several sessions. It took 26 pieces to cover and almost every one was a compound curve.
The heat gun was needed on every section. The hardest sections had a combination of convex and concave surfaces like the little section right behind the cockpit and the battery hatch. There were a lot of do-overs but it was a valuable learning experience.
Jon
TooJung2Die
The elevator is hinged using monofilament. Mono is great when the wood is too thin to slot. When the push rod length is just right a couple of drops of CA on the heat shrink tubing locks it in place. The control horns are gift card plastic.
The ailerons are hinged using Tyvek mailing envelope. The push rods are made from short Z-bend wires connected with heat shrink tubing.
The wing is supposed to be glued to the fuselage. Since this is going to be a belly-flop lander I added bamboo skewers to hold the wing on with rubber bands.
How much weight does document laminating film add?
Before covering it weighed 4.79 ounces. Covering, mounting the electronics and finishing the control surfaces added 0.64 ounces. I'd estimate the film added 0.5 ounces to the airplane. The CG moved to the rear as expected and now the battery has to be right behind the firewall. It'll be interesting to see how much weight painting it adds.
Jon
TooJung2Die
I've always wondered how much weight the covering film and paint adds to the weight of an airplane. I never stopped to weigh the model between steps until now. Paint does not add as much weight as I thought.
That's 5 airbrushed coats of very thin acrylic paint. I stopped adding coats while the paint is translucent and the balsa frame can be seen though the covering. One coat of clear aerosol lacquer on top of that. The black acrylic trim was masked using Scotch Removable 811 tape and brushed on. The paint job only added 0.4 ounces. At this point with the battery on board it weighs 5.82 ounces (165 gram). Ready to fly it'll be well under the 7 ounce, 200 gram goal. Not bad for an airplane with a 30 inch wingspan.
Next steps are attaching the canopy and applying the decals.
Jon
