Hi everyone! This is my first post on this forum, and I wanted to ask a question regarding my Quadcopter.
I'm using a 250 frame with a 3 Cell 2250mAH Lumenier battery, and it has 12 Amp BLHeli ESCs, along with EMAX MT2204 KV2300 Motors.
As I have only flown this drone for roughly three months, and I'm just getting into FPV, I lack a certain amount of experience with how everything works and what works with what.
My issue is regarding the motors/ESCs, during set up, when I arm the drone, three of the four motors spin up. (occasionally two, but rarely) The fourth motor will (from what I know) try to unsuccessfully spin up, and ends up jittering and not spinning at all. I've kind of set up a rhythm of count to two, arm it, and on three, spin the nut on top in order to get the initial spin up going. After this tedious and repetitive process, once it gets spinning, the motor works perfectly, and the Quadcopter flies as one would expect. Obviously, this is still not only an inconvenience, but also a safety issue, and so I tried to figure out how to fix it. My father and I both have different theories on how to fix it. He says that we need to get a 2250mAH 4 Cell battery, and with its additional voltage, it will provide enough power to get the initial spin going. My idea is replace the 12 Amp ESCs with 20 Amp ESCs as I assume they are getting overloaded or something along that line (They don't heat up very much, but that may be from the cooling of the propellers spinning on top)
So, here I turn to you. I want to get an idea of what the problems might be since I know it isn't a bad soldering job or bad bullet connector connections as I've rigorously checked for this issue. I want to have an idea of what needs fixing before I go buying Willy Nilly, and I hope this is an easy answer. Thanks to everyone in advance!
*Edit* I will note that I noticed the the heat-shrunk part where the wires connect to the motor, when facing down, make it jitter, but once moved to a horizontal position, the motor spins up, this happened both during arming and whilst armed and jittering.
