Solved Help me troubleshoot please.
So I built a "trainer" that has a 26'' wingspan that is powered by a 1300kv motor on a 3cell with a 7x5 prop. I threw it into the air and it pitched up hard so I added a bit of nose weight but now it glides for a few feet and then crashes itself into the ground.
Also my prop mount thingy is loose so I had to hot glue it on. How can I fix a loose prop mount?
Thank you for your help!!!
leaded50
the prop mount if are not the bolted to cap one, the style as on the picture here, does hold on the motoraxle by clamping to it, when prop screws on. Either you then got a prop holder with wrong size, or not screwed the prop & propholder enough on. hot glue will never hold.
If thats loose. you also loose motor thrust/effect.
give us a picture of how youre prop holder are fastned to motor. is it a thing as you stick on the motoraxle, or not.
Does it seems similar a bit to the type of my picture?
One type are as that one the picture. An other is screwed direct to the topcap with 3-4 screws.
My prop holder actually broke after I crashed lol. But yes it is the thing in the picture. I just push it on the motoraxle put the prop on it and then screw on the tap cap thing, no need for screws and stuff.
leaded50
ok, that things clamps to the motoraxle only by pressure from when its pressed together when propnut is screwed on. To little moment, it slips, to small motoraxle, then how much it could clamp together, it slips. They are sold for diferent sizes of motoraxle diameter.
When you see on the picture you see its "4-slits" with hole in the middle. When nut is screwed on, the 4 slits get smaller, and smaller (then also the hole in middle will be smaller) When the slits are totally jammed together, its reached its minimum holesize. If that is bigger than your motoraxle.... well it slips.
Ohhhhh I tried doing that with pliers XD
Timmy
Depends how fast you are going, the weight of your plane and what kind of wing you have. If you provide that info I can help you. If you know where your center of gravity is suppsed to be, you can put your fingers there and see if the plane tilts down or up or if it stays level. If it tilts way down, its nose heavy. More pics/videos could help too
leaded50
@GreaterAviation , one tip here though.... if been me, i would had maked the horizontal tail surfaces wider. In RC planes its some recommendations.. (cant find at moment though...) On your picture it seems be at least smaller than 1/3 of main wing... i would tryed approx 40% span of the main wing... it would help a lot on both gliding, and reactions on control surface movements..
JasonK
your probably looking for one of these (yes I have them bookmarked):
https://www.flitetest.com/articles/easy-aircraft-design
https://forum.flitetest.com/index.php?threads/determining-control-surface-area.62991/#post-565944
