I did get one of these type of connectors to charge multiple UMX batteries from a standard charger but.....
http://www3.towerhobbies.com/cgi-bi...5qU4G6Y-_K_pxYhqIyO4Wrraz0hvsPRJURBoCRWXw_wcB
... but I usually bring this one with me when flying micro's and just charge up a 2200 mah 3 cell ahead of time to act as a mobile power source for the UMX charger. This one handles all the different weird little batteries, and doesn't tether me to a wall outlet or a big power source.
http://www.ebay.com/itm/like/131350923839?lpid=82&chn=ps&ul_noapp=true
Interesting.... mine did the same thing last time I had it out. Pretty much finished it off. Looking to repurpose the electronics into something else.Hi - I am admittedly a newbie, and I've had good success flying the Sport Cub S in Beginner Mode.
I have two Sport Cubs...I crashed #1 into a wooden fence and I was unsure if it could be repaired properly, so in addition to buying the necessary parts to fix #1 I also bought #2. Both are BNF and I'm using a Spektrum DX7s. I did get #1 up and running again and it's seems to fly just as it did when it was new.
My problem is with Experienced (and possibly Intermediate) Mode. Whenever I go into either mode it immediately nosedives toward the ground. Today I couldn't switch it back to Beginner Mode quick enough before #2 went nose first into the ground (another motor mount whacked out position). I then switched to Cub #1 and got it up to about 75 feet (in Beginner Mode) to give myself plenty of time to switchback to Beginner Mode. It did the exact same thing - it immediately drops the nose and heads straight for the ground. This time I switched back to Beginner and it quickly leveled out. Both instances happened with the throttle around 50% - 75%.
Any ideas what is going on here?
they are adhesive on, there is a lip on the back of the wing part. I start in the front with a thin blade, I more or less ever so gingerly used my fingers and lifted up the wing, will start to separate. time is in on your side don't rush it I my still have my old spare parts I can demonstrate with a video.if need be.?
Dispizion that is normal if the transmitter was not turned on it will not initialize inverted and the bind light comes on if transmitter is not on.
