hotwax Plan Index
hotwax
Hi mactek,
your wingtips are okay as they are.
In the old days, we made Styrofoam and Balsa wings for the Stick with just these wingtips.
Good Job, keep doing
hotwax
Hi all,
looking into outerzone.co.uk, I had this idea of spurious 50s Jets.
I quickly found the plan for the Cherry Bomb, downloaded it, made some rough calculations, took pencil and paper and here is the prototype. I made some minor errors, but nothing serious.
It's an experiment as I blended a standart Flitetest profile into a modified KFM-1.
Will it work? I don't know.
For a picture, look at post #1
hotwax
FB Cherry Bomb made its successful maiden.
It's a smooth flyer both upright and upside down. Slow speed handling will be subject to further investigation. Maybe a bigger rudder is needed.
I did a rolling circle and some loops and rolls. All went well, landing was smooth with little flair.
hotwax
FB Cherry Bomb got its vertical stabilizer enlarged and is flying fine, even at low speeds and high AoA.
Oh I like this stuff
hotwax
got Retro Fever
Hi all,
back at the building board, I started a new mini series: Foamie Antiques
1. FB Graupner Terry
2. FB Hegi Auster
3. FB Robbe Rasant (or Rasant Speed?)
It's a selection of well known German Classics. Hopefully I can turn them into planes, that can raise memories.
FB Graupner Terry so far:
hotwax
The FB Terry is nearly ready to fly. Some final touches at the paintwork and it's off the board.
It's a swappable!
I borrowed the wing profile from the FB Funk Max with a chord of 200 mm.
Span 1050 mm, Weight 686 gr, Batterie 11,1 V 1000mAh
Paint is household acrylic paint, rolled on. (30 gr paint). Black and grey areas are adhesive tape.
Maybe I should do a sport wing with only little diheadral and ailerons?
hotwax
red-white-red, very nice choice of color ;)
Sorry, not my idea, it's from the Graupner catalog:
Very interesting, the catalog from 1972 gives 1100 gr weight, my plane is unter 700 gr, I believe this counts as progress.
And finally I got the catch: Austria ... red white red ... okay, that's your point :))
I might have to try painting a model of mine too, your terry looks so damn clean! Though Ill wait for the next full sized model as paint might be too heavy for minis
Also d graupner catalogs are indeed a good source of inspiration, thanks for that! My dad has tonns of them lying around at home somewhere. Ill for shure check some of them.
