kah00na
I'm using CleanFlight and have two 3 position switch (really I'm using the two dials) on my Taranis setup. I have to switch between the P, I, and D yaw settings and the other to increase/decrease their settings. I'm using PID Controller 3.
The problem I'm having is that I have no idea how to tune the yaw or what to look for.
Here's how I was trying to do it (unsuccessfully):
Start P around 0.5, and start I & D on zero
Get in the air and start increasing the P until the tail starts to swerve back and forth - then reduce it a little till it stops
Then, still on P, yaw left and right and lower P until the over compensation at the end stops so when it yaws it just slows down or stops without bumping back in the opposite direction.
At this point when I try to hover, it slowly yaws (usually to the left) - probably because "I" is set to "0".
I then switch to the "I" and start to increase it until the slow yaw stops. Then I test how well it stops after coming out of a yaw and check if it over compensates. Eventually it starts over compensating again and I lower it down a little till it stops.
At this point it feels a little sluggish on the yaw.
Then I switch to start adjusting "D" and as I change it, it starts over compensating again but when I lower it back down, it starts to not hold its position very well and I get frustrated and question why I even bought a Naze32 for a tricopter because my KK2 is AWESOME and just works (like in this video):
At one point, I thought I had the Naze32 tuned pretty well but when I started doing faster forward flight, I started getting a sway in the yaw again. I even tried FPV thinking I wouldn't fly as fast and it would be alright, but i was wrong and I started getting dizzy!
Has anyone ever tuned a tricopter yaw with a Naze32? I need help. This is about the 4th time I really given this a good effort. If I can't figure this out this time, it will just go back on the shelf until I feel like trying again in a few weeks.
