or after you land!
its a nice day to fly no wind.. be sure to get a couple of battery's in
chris.
or after you land!
i was gonna buy some FPV gear.. but i was sitting here thinking.. if all im doing is hovering FPV would be useless as you need to be going in a forward direction to keep your bird in the air, hovering FPV probably sucks. unless you have a gimbal i guess.
You're right. Hovering FPV is more difficult than flying forward.
I fly my ZMR on gemfan 5x3 props and mostly with a 2200 3s 20c http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=15019 as i have more of them available, i also have 1300 3s http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=20423 the same ones you have the rolls i did were with the 2200 packs. i would prefer having higher c batteries but just saying when your learning almost anything works at least for a while.
BTW here is the video i was talking about
A little late to the party but well done on completing and flying your craft! It'll be loads of fun![]()
Indeed Chris, glad to hear you're enjoying it so much.
I started with a RTF DJI Phantom which I bought with a friend but it was too small to lift any substantial camera so I built a larger 700 class hexacopter which I use for AP for my side business. I then built a tricopter and a large 400 quad out of the crashed pieces of the phantom
Finally I ended up with the 250 miniquad and this thin has dramatically increased my flying skill by leaps and bounds and now I am able to fly the huge hex with a lot more confidence for way better aerial video and composition.
I look forward to seeing what you come up with next.
Cheers
hi, yeah, stick time will be the key to good AP i think.. well i have a new frame on my desk and am starting to collect parts for it. i have 50 percent of the parts here and more arriving every day..
also i ordered some 450 size helicopter size skids.. and they are the right width but just to tall i think.. so im gonna try one other options.. worse case ill use them if it keeps rocks out of my props but some times you have to take what it looks like in consideration..
anyhow, this next build my overall goal is to build a flying tank that this desert will have a hard time breaking.. so yeah that is my goal. LOL.. pure carbon, and 5mm thick arms should help i think.. and stainless hardware.
il probably do a build for it if anyone wants to see it.. ill probably need help building it anyhow as im gonna go fancy and use that parachute chord stuff, and add FPV gear.
unfortunately its gonna cost way more than this this kit ever did.. but at this point how much im in the air frame.. i think i should just forget how much money i will have in the air so i do not cry when i crash.
chris.
@jhitesma great idea, filing CF under water! i didnt know you could do that! duh..
