danskis
Firstly, the title is a little misleading (so far) because this is mostly about elevons so far. If this doesn't need a new thread let me know and I'll delete it. Just point me to the right one. Or any other resources out there on the web for this transmitter.
And right off I"ll say this may not be the right transmitter for me (but I really really don't like taking multiple transmitters to the field) as I prefer set it and forget systems.
So here are the questions:
Why is the red and green light on, on the front of the TX, at the same time?
How do you set up elevon mixing?
Why does it say the model isn't saved?
I have been able to bind it to an Orange receiver and setup D/R and Expo using Andrew's video here but he doesn't have one on mixing.
And there is Alan's video here on mixing. Easily found on YouTube. I don't like it because he does all the mixing in the Mixer which is confusing.
Here is another video - link below. This video on the Deviation Forum tells you (sort of) how to set up a basic template so your ailerons are reversed and working correctly. You can see this in the aileron mixer on Page 2. The mix from this video is in the below spreadsheet. Do this basic mix and then go into the buttons on the left side, Thr, Ail, Elev. and do your reversing there.
This is the only video on this forum page and its a ways down.
https://www.deviationtx.com/forum/search?query=elevon mixing&searchdate=all&childforums=1&catids=11
