If the receiver test works fine, you could just unplug the buzzer and try it anyway. If you don't want to do that, you could set it up like a normal plane without the KK mini, and set your transmitter endpoints on the motor tilt channel so that you can go between horizontal and 45 degrees (Maybe more, but you would have to experiment) to horizontal so you can do some STOL flights, and mix in some rudder with differential thrust. You can then come back to the KK mini or another board later, but you will have had a chance to fly it.
EDIT: Ive noticed you only have 6 channels, so for my second suggestion you couldn't have rudder, but you could use rudder and gear for the tilts, with a mix so that the gear controls the rudder and with changed endpoint settings, and then aileron and aux for the 2 ailerons, with a mix so that aileron controls the aux. You could then set up flaps too to help with STOL abilities
