nice mounts
I have made new motor mounts that holds the motor better and are easier to change if broken, no zip ties needed.
All files for 3d printing can be found here: http://www.thingiverse.com/thing:163794
nice mounts
Sure looks like it unless the second pack is a dedicated FPV supply...What does your power supply look like?
Do I see two lipos wired in series?
WOW, two 2200mAh batteries. What is your all up weight and flight times? Is the copter still acrobatic?
Does an 'I' quad need to be square? I know that a 'I' quad is basically a 'X' quad with a different frame. Just finished assembling my first 'I' quad and I noticed that the width from motor center to motor center is 10" and length from boom to boom is 12". Does this rectangle shape affect performance? Will it roll faster then pitch? Are there settings in the KK2.1 that will need to be set differently?
With all the gear on, including FPV stuff and NO batteries, 650g.
With the two 2200mAh 3S it comes to 970g.
About flight time, I have't really pushed it but with one battery it is around 5 minutes.
That's crazy. I use a single 2200mah 3s and can fly for 15mins+.
Hi everyone,
I'm going to attempt to build myself a Knuckle H Quad.
I was doing some calc on eCalc and with the specs used by the recommended electronics it says that I'll be burning the motors as I'll have 11.25A when the motor limit is at 7A.... am I wrong?
