RAW maiden flight of RMRC StratoSurfer. (no audio)
RMRC StratoSurfer
Tattu 4200mah 3S battery
Matek F405-Wing FC running ArduPlane 3.9.6
RMRC mini GPS
RMRC 1.3ghz 400mw VTX
RunCam Owl Camera
FrSky R9 RX
Craft & Theory Telemetry Cable (for s.port inversion)
Making adjustments to the FPV gear. Switching from 1.3ghz to 5.8, Modified Camera settings, and re-organized the OSD fields to my standard layout. Also need to pull the FC and fix a booboo I made. Duh, I set the VTX/CAM voltage regulator to 12v. That would be fine on 4S, but on 3S, it is causing problems since the regulator can not pull up to 12v and ends up dropping V further, especially as you get further on in the pack an voltage starts sagging.
Forgot this thing has a rudder. Need to coordinate turns too. LOL
Cheers!
Litter Bug
RMRC StratoSurfer
RMRC mini GPS
RunCam Owl Camera
FrSky R9 RX
Cheers!
Litter Bug
