Look what I found, laying on top of a closet!
Johan
#21
Why does he need Popsicle sticks to chew when all the scrap balsa is just sitting there and could be used the same way by chewing it and then gluing the pulp into the required piece? :p
Thurmond
Yes! chewing as we speak :), kidding, it is way past bedtime over here ....
Did taste it though :)
tramsgar
#22
Thurmond
I stand corrected, that would be a much better idea. Also, balsa does not wear on your teeth to the same extent. Good catch!
rcspaceflight
creator of virtual planes
#23
I used Elmer's school glue on my balsa builds... don't do that. It takes forever to dry and isn't that strong of a bond. I did it out of cheapness and this is exactly why I gave up on my Bird Dog.
I kind of want to build another rubber band powered balsa build, but use actual glue and mount my camera in the nose then throw it off the cliff on my parents farm.
Johan
#24
Did a little bit of measuring, cutting, gluing and clamping today.
You'll probably notice there are no control surfaces whatsoever, this is just going to be a 'dumb', non-controable.
I find the building process relaxing after a long day of work.
Here are some pictures:
PS, took a while to get the dihedral figured out
xuzme720
Dedicated foam bender
Works for me, I don't judge...
If you wanted to make it R/C, you could get some balsa stock and add frame, as outlines of the control surfaces, to the structure. Then all you'd need to do is cut the control surfaces loose at the balsa frame and Bob's your uncle...(don't know if they use that expression anywhere but England...it just means you'll be all set.)
Johan
#28
Hmmm, you made me reconsider. Of course it is a lot more fun to be able to have some control...
I'll go back to the drawing board and also find me some balsa (or balls as autocorrect just suggested :))
#31
I turned my rubber band me-109 into electric for my first scratch build plane and it was hard but I did it, although I messed up on the ailerons so it doesn't fly. But I did it and it was rather cheap
Johan
#33
Thanks guys for all the suggestions, I'll check it out !!
My kit is not from Guillows, but Winleader, but that should not make much of a difference.
although this kit has been hiding on top of a closet, it is still sold:
http://hobby.uk.com/flying-scale-models/balsa-kits/wingleader-ww2/hawker-tempest-mk-v.html
And guess what: bottom line on the product page reads "We’ve heard that one builder even managed to install electric power and micro R/C. Now that would be fun!!" :)
Johan
#35
Some new pictures of the fuselage.
I have to figure out where to make room for battery / receiver etc. But thought it would be best to see it assembled to get a clear picture of the possibilities (might regret that later :))
And no, the weird 'bend' in one of the stringers is not part of the design :)
Out of curiosity I weighed both parts:
Wing: 3.5 grams
Half a fuselage: 7.5 grams
Probably half of it is in the glue :)
Johan
#37
Thanks!,
I figured out the reason for the 'bent' stringer:
I'd made copies of the original plan on smaller sheets, luckily at 100%, so scale was still right.
I built the fuselage in two runs (my cardboard underlayment was a bit small).
Apparently I did not properly line up for the rear half and placed the second support behind the canopy slanting forward.
This caused the holes for the stringers to not line up.
Well, this is my second balsa built ever and the last one was over 20 years ago (tiger moth), so it is not too bad :)
BTW what would be better (weight wise): use the paper that came with the kit and use the 'shrinking lacker' (don't know the english for it, we call it 'spanlak')
or go with monokote or something similar (kind of removes the warbird look I guess)?
xuzme720
Sounds like it might be what we call Dope, as in Dope and tissue covering. My first balsa build was a freeflight glider that I covered in tissue and dope...what an ordeal! It flew well though, right up until it crashed into a tree trunk on a long landing...
