Help! Making my first Quad!
ELRS has better range, but it is the RF modulation technique, not the serial protocols that make the difference. and depending on the PWM refresh rate that you select, the modulation and range can differ. It's tuneable depending on the application you wish to set it up for, IE racing vs long range.
ExpressLRS receivers can communicate using a variety of serial protocols including SBUS
  • CRSF (Crossfire) + Inverted
  • SBUS + Inverted
  • SUMD
  • DJI RS2 Pro (Modified SBUS with pre-configured limits)
  • HoTT Telemetry
  • Tramp
  • SmartAudio
It that why I saw a Elrs Tx with 2.4ghz? I thought it was only 900mhz.
SBUS / Ibus is what the tranmitter uses to communicate with the Transmit module in your transmitter. On the Receiver side, it is what the receiver uses to talk to the flight controller. What happens in the radio waves is what the tranmitter and receiver modules do. So FrSky, FlySky, DSMX, ELRS are the RADIO protocols that those modules use to talk to each other over the radio spectrum.
So basically different Tx's speak different languages and the Rx is the interpreter for the FC?
ELRS is pretty well documented if you can wrap your head around it. The screenshot above with the different packet, data, and modulation methods was taken directly from the ELRS documentation.
Close. The TX is like the FC in your hands. It takes all the sticks/switches, dials, etc and converts it into a signal that the TX module can use to send it out over the airwaves
F405 is still the way to go unless you have a need that requires more processing power. The F411 and F722 are short on memory which limits their support and functionality. Higher end F7 and H7 processors cost more with not much added benefit for flying quads.
Oh okay. I thought the F405's were not the thing any more.(But I guess no one ever got rich selling old technology lol) Thanks! F405's are differently cheaper.😅
