Flyingshark
I've been working on this project in bits and pieces since last spring, so I thought it was finally time to make some plans and build a prototype. For those of you who don't know, the VariViggen was Burt Rutan's first homebuilt design, so it's basically the parent of the VariEze and LongEz.
This will be Mighty Mini sized, so a 20 inch (508mm) wingspan and run off of an 1806 and 2S or 3S. I'm not quite sure if 2s will be enough power since this is a little bigger and a bit heavier (more formers) than the FT LongEz
Anyway, here's my CAD progress so far. I started designing this in Inkscape, then got confused and decided to learn how to use Fusion 360 and continue it there.
The wing is just going to be a flat plate, so nothing too complicated. I'm planning to do a posterboard turtledeck and cockpit if that doesn't turn out to be too difficult. Since I recently got an Ender 3 Pro, I might make additional 3D printed parts, (say, engine intakes/exhaust, a better cockpit, etc.) whenever I get that fully operational.
Oh, and I'll probably add a prototype paint scheme poll some time, when I get some ideas for that.
