Hi All,
Ran into a problem today that may have multiple reasons why my Mini Arrow didn't fly. I've flown for years so it's not a thumbs issue, it could be a "don't know what I don't know" issue... maybe the launch needs to be more forceful. No idea.
Symptoms - Multiple launch attempts that saw the plane nose down almost immediately after launch.
All preflight checks were fine.
Motor - Emax RS2205 S - 2600kv Max Thurst - 1021G
Prop - Standard 2 blade APC 6x4. installed numbers facing forward.. plenty of thrust in the right direction.
ESC - Emax 30a
CG - Was good after moving the battery as far foward as possible.
My gut is the prop or thrust angle... I'm leaning towards the prop as thrust angle looked to be fine. Another option could be the fact that as i've never flown or configured a pusher, I did something wrong. There was little to no response from the control surfaces as there was hardly any airspeed and being a pusher, no air from a prop in the nose to help.
Do pushers need special props? As I've never installed a prop "backwards" the prop blade was pretty much touching the motor.
As always, any help would be greatly appreciated.
~ Dave
Link to video of one of the launches. This was the last attempt but the previous 3 attempts ended the same way.
Pic of Prop on motor.
ESC - Emax 30a
~ Dave
