Karolyiboys
Hello There! Do you guys know when the Mini Corsair Version 2 is coming out? They've been hinting a lot about it in recent videos, but I haven't heard a real date, or just even an estimate. Thanks ahead, Karolyiboys
I’ve got all the supplies needed to build the giant Corsair. All I’m lacking are the PLANS! Is there any way to contact Noah or Josh and get them to post the PDF of the plans they used? I’d be happy to pay for them.
Like @w1lp33 said, you can just upscale the full size plans to 185%. Use monster foam for everything except the fuselage and wing skins. You’ll want to make those out of normal thickness foamboard so it’s easier to mold. Just keep in mind that you’ll need to increase the size of the formers by about 4mm to account for the thinner foam skins.I’ve got all the supplies needed to build the giant Corsair. All I’m lacking are the PLANS! Is there any way to contact Noah or Josh and get them to post the PDF of the plans they used? I’d be happy to pay for them.
is there a specific build video for the mini corsair 737 mm? or do we use the build directions from the mighty mini?
It’s a different build. The structure of the new mini Corsair is a better design than the master series. Turns out, they didn’t just scale up the new mini, but combined it with the wing of the master series full size Corsair. They could solve so many problems for me by just posting the PDF of what Noah used to build it. Don’t understand why they won’t. I’ve just about got a 200% scale of the new mini built. Have had to modify a few things and add a box spar to make it work. It’s a tad smaller than their giant Corsair.Like @w1lp33 said, you can just upscale the full size plans to 185%. Use monster foam for everything except the fuselage and wing skins. You’ll want to make those out of normal thickness foamboard so it’s easier to mold. Just keep in mind that you’ll need to increase the size of the formers by about 4mm to account for the thinner foam skins.
thnx!
What is your ready to fly weight?Finishing up FT Mini Corsair from kit. I have about a dozen FT builds under my belt. No master series yet but this one seems like a step towards that. I have to say that this is the best kit I have done yet. The kit itself is very complete and even includes nice decal set. This one introduced me to some new techniques that I like a lot. The forming instead of folds makes this a real beauty. This is one great design I think. Only issue I have had was struggling some with the rudder and elevator control rod routing. I found too much bend when installed according to plans and that resulted in difficulty moving them. I moved the cut out holes in the former a little higher, took out some of the bend and they work smoothly now. Need to figure out how to do some landing gear, finish the electronics and then on to maiden.
We found the Zero flies better between the two, but then again the corsair may be a bit heavy in comparison due to the complexity of the wing. Only my ol' man has the corsair however, he made it before I could trace the plans onto a sheet to scratch build one. So I only got a zero while he had both.The existing mini corsair flies amazing if you keep it light.
haven't weighed it yet...some build still in progress. Landing gear today. Using 3s 850 battery for starters. Can't find any specific recommendation though.What is your ready to fly weight?
And please tell us what you used for a battery?
Thx 😃
Thx 😃
