Motor won't start, ticking and rocking
Aran
Hi guys,
I've got a turnigy 35-30 1400kv motor to go on my EPP FPV. Connected to a 40a esc with bec.
When I start up the system. I get the tune and then no further beeps to indicate all is good and no further beeps are made. However, whenever I give some throttle on my tx the motor just ticks and rocks slightly.
Other servos connected are working fine. Oh and when I give elevator or rudder input on sticks the motor will start twitching and ticking.
Any idea what the issue could be?
Thanks all,
Aran
rcspaceflight
creator of virtual planes
#2
It's probably from only two of the three wires being connected to the motor. Might be a bad connection.
I've also had this happen from getting snow/water in the ESC.
adamd
skunkworx hobbies
#5
yep one phase is missing! well thats how it sounds from you description. you can isolate it by removing one phase at a time. try to run it at as little power and time you can. when its not spinning there is no counter emf to keep the motor from over amping and burning your esc or motor. also if a phase is out then your tune sound can be a little week depending on the esc
SteevyT
#7
Does it do it at all throttle settings? My set up for whatever reason bounces back and forth rather than spinning at the lowest throttle setting if coming up from a stop.
Aran
#8
Mine is doing the "rocking and ticking thing" at any throttle setting. Will be attempting to fix this evening.
Aran
#9
Hi All, Quick update, last night I re-soldered the three bullet connects from my motor to the ESC and now the Motor powers up fine.
With the dodgy soldered connection in mind, I re-soldered everything! (just in case).
Now a new problem has reared its Ugly head. (I'll create a new thread).
Thanks all for your help.
#10
Please link to the new thread when it is up. I am having my own motor issues and resoldering the connectors didn't work. I found out after taking it apart that the wires to one of the windings had become disconnected so I'm sending in for a replacement (not enough talent here yet to rewire it). That being said, I'm hungry to learn more about fixing these things.
adamd
skunkworx hobbies
#11
I find with soldering keeping your tip clean hot and tinned is the way to a nice solder. Remember to put flux on thr two peices and pre tin even if the wire come pre tinned (they might not use the same solder as you!) And the last thing and most importantly patients! Even if you have everything right but rush or wiggle the wire when its settling you can end up with that pointy rough cold joint.
