Okay, so I have a quick question for all you covering pros out there... (or even not pros but with some experience.)
My plan was to have the fuselage split down the length, Green on bottom and yellow on top.
(Top of wings yellow and bottom green with a checkered stripe on the Left wing...)
I saw from another post/thread that in order to do a seam, you either need something under the seam (spar) or use a solvent (that apparently no one makes anymore (Probably causes cancer in California.)) or you may have issues when you shrink...
So I'm going to try out a test tonight, and see if crossing the holes in the fuselage will cause issues...
I have two main plans (of attack.)
1. simplify the scheme and just do green on the lower face (bottom). Wings the same as before and now maybe the tail feathers checkered.
Should look "okay" but not as nice as a split job.
2. cover the side with yellow the green on top... (but that's where the issues might creep in... correct?)
Thoughts, ideas, suggestions? (I'm all ears.)
