agates1967
Hello everyone!
First of all, let me know if I should be posting this thread somewhere else, I'm new to the forum and its ways.
I have been following FliteTest on YouTube for a while now. I started RC flying in about 2003-2004 with a 2 channel foam winged V-tail-ed plane, that gave me enough confidence to lose it in a huge gust of wind one day. When that was gone I bought the Typhoon 3D, and I still fly that one to this day. I haven't crashed it hard enough to quit flying it yet!
After watching FliteTest for some time I wanted to build something myself from scratch. I tried 3d printing one of those spitfire or mustang models with the intent to make it RC, but I think it would have been too heavy. I watched some of the speed build videos and thought the FT Mini Tiny Trainer would be a great place to start. I bought a foam board display stand and printed out the downloadable pattern and got to work. I went through this one with the build video, starting with the chuck glider nose and simple wing, this gave me enough practice to finish the rest of the plane with great precision. I powered this one with an Eflite Park250 motor, a 800 mah 3S battery, and a 6x4.5 prop. I cut the motor mount and control horns from old credit cards with a small hobby laser. I tell you what, this plane flew so straight and smooth on the maiden you couldn't wipe the grin off my face. I still love flying this one.
After a few flights with the mini trainer I wanted something with a little more realism. I downloaded the plans for the mini corsair, and built that one in a few days time. I had a 2204 2300kv drone motor and got some small 3 blade props for it. The first flight was under powered, I think the esc wasn't set right for the motor I had. I put a different, smaller esc in and now it has about 3x thrust to weight! First flight broke a blade off the prop. Second, more powerful flight, I think the CG was too far back and it was too unstable for me to fly and broke another prop blade. I will add some weight to the front and try again this week.
Before I got to maiden the Corsair mini I wanted to start construction of a bigger plane. I looked online to see if anyone had plans for a DC3 type aircraft, I caught the tail end of the Plane Savers DC3 restoration and wanted to fly something like that. I hadn't found any complete plans yet so I set out to design it myself. I use Autodesk Fusion 360 for personal projects so its free to use, and I found some ways of designing flat-faceted models to make flat patterns. When I get done testing this new design I want to share it and see what other people are able to do with it.
Here's a little animation of the 3d model...
Here is the current status of the test build. I am trying to make the engine cowling from paperboard, similar to how the corsair was constructed. The motor pods use the same mounting as the mini corsair, so they can be swappable!
I plan to put some fixed landing gear on this since the motors aren't very high. Also if this works well I'd like to re-design it to have a round-ish fuselage like the corsair, for added realism.
Let me know if there's anything else you'd like to see on this new plane. I'm pretty proud of my progress so far. If I can get a friend to help I'll try to get a video of the maiden. The motors I think I'll push as far forward as I can to help get the CG forward, and the battery will surely go in the nose. If anyone has tips on if I need any thrust angle, or anything on getting something like this set up initially I'd appreciate the input.
