Thanks every one, I'm building a laser cut speed build kit. I would love to do scratch builds later but I still have not found a good option for purchasing foam board in Australia. The only foam board I could find was for architects to make models and costs around 15 bucks a sheet.
Ran into the same thing when I was building my first plane. I've seen some foamboard sheets in Officeworks but they're $13 and look to be a lot more dense and the dollartree foamboard that flitetest use for their kits.
There's an article about buying foamboard in Australia here
https://www.flitetest.com/articles/foamboard-in-australia, and while it's probably a bit out of date now, it does confirm that our options are fairly limited.
I'd strongly recommend buying a 50 pack of foamboard from flitetest (or one of their affiliate redistributors). If you're just getting into flying then you're going to crash, and having a large stash of foamboard to draw on for repairs makes that a bit less of a bitter pill to swallow. If it weren't for being able to rebuild/repair planes I probably would have given up a long time ago (but then again I'm not a very good pilot
The shipping costs to get a package that size from the states are massive, it probably doubles the all up cost (I think it came to a bit less than $200 all up). However:
- The overall cost per sheet comes to about $4 a sheet which is far cheaper than anything you'll get in AU.
- It will last you a long long time. A mate and I got a box of 50 early last year and we just got half way through it (and have built at least 9 planes from it).
So while the outlay is initially expensive (relatively) it will save you money and frustration in the long run. If you can go halvies with a friend, or someone else close by then that definitaley takes the sting out of it.
Hope that info helps, and hope you have much success with your flying!
